Need Help with Speedometer,ABS light, Check Engine Light
Old Jan 23, 2001 | 01:07 PM
lordconqueror's Avatar
lordconqueror
Old Oct 18, 2001 | 09:11 AM
sgibson's Avatar
sgibson
I have a 1999 Ford Ranger SB, 4 cyl. A few days ago I was driving to work and the speedometer quit working, the ABS light came on and the Check Engine light all came on at the same time. Does anyone know what's going on with this and how to fix it? I can't afford to go to the dealer right now. Help.
Old Oct 22, 2001 | 02:09 PM
79_1ton's Avatar
79_1ton
The next time that the abs light comes on take and stop the truck. Look down to the fuse box and going into the back of it should be an orange and white wire. Turn the truck back on, just the key don't start the truck, and ground out that wire, as soon as you do so the abs light should start flashing a series of beeps, count the beeps and the series of these beeps. Depending on the number of beeps this will tell you the problem. Get that number post it and i will try and give you the actual diagnoses. If you don't get any beeps at all I would start pulling fuses in the panel and even check the power distribution box, under the hood, usually back towards the passenger side above the solonoid. Hope this helps you out some.
Old Oct 26, 2001 | 04:21 PM
sgibson's Avatar
sgibson
It was the speed sensor, located in the differential.
Old Oct 30, 2001 | 03:16 PM
50Cobra's Avatar
50Cobra
I posted a similar question above, the speed it determined in the differential? So the wires come from the differential and go to the speedo? If that sensor is bad, what is involved in changing it?
scratcherky
Apr 24, 2002 07:52 PM
Mar 12, 2002 05:05 PM
dric8792
Nov 24, 2001 11:22 PM
Eddie
Nov 2, 2001 09:37 PM
freddy
Feb 6, 2000 11:34 PM
