ABS warning light
Old Dec 31, 1969 | 06:00 PM
Guest
Guest
Posts: n/a
ABS warning light
Old Mar 11, 2002 | 07:06 PM
Ford 4 Life's Avatar
Ford 4 Life
ABS warning light
I own a 97 Explorer 5.0L V-8. Sometimes not all of the time the ABS warning light stays on after start up. I've cut the engine and restarted it and at times the light will stay on and other times turn off. I show no difference with the brakes or handling. Has anyone had this problem or knows what the hell is going on?
Any advise would be helpful.
Old Mar 12, 2002 | 10:51 AM
FortyFords's Avatar
FortyFords
ABS warning light
[updated:LAST EDITED ON 12-Mar-02 AT 11:52 AM (EST)]Try disconnecting the battery for a few minutes!
if it persists you need to take it in,and have some one read the codes
that are being stored in the pcm.
could be the abs module or sensors going bad.
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
Old Mar 12, 2002 | 05:05 PM
Ford 4 Life
ABS warning light
I will try that.
Thanks FORTY FORDS.
