Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Hand held tack
Old Dec 3, 2004 | 09:24 AM
mkrog's Avatar
mkrog
Hand held tack
Where can a person get a hand held tack,I can't find one anywhere.
Old Dec 3, 2004 | 03:57 PM
Torque1st's Avatar
Torque1st
Posting Legend
JC Whitney has a couple of pages full in the print catalog. Most auto parts stores should have "engine analyzers" etc.
Old Dec 3, 2004 | 05:16 PM
mrxlh's Avatar
mrxlh
What are you going to be using it for?
Ryan
Old Dec 4, 2004 | 12:44 AM
mkrog's Avatar
mkrog
Don't need a engine analyzer just a hand tack.
Ryan,I use it to set idle speed and carbs.
Old Dec 4, 2004 | 01:07 AM
ivanribic's Avatar
ivanribic
I don't see why you couldn't get a $15 Sunpro tach and wire it up with some nice jumpers with aligator clips on the end. You'd just clamp them to the battery posts for power and one to the coil or tach output. Put a high powered magnet on the base and you could stick it anywhere while you tune the engine. That is if you can't find an actual handheld unit.
Old Dec 4, 2004 | 04:08 AM
Crash687's Avatar
Crash687
Look into Grainger, they carry both contact and non-contact tachometers. Type in tachometer in the search box, should pull up four pages.
Old Dec 4, 2004 | 04:53 AM
Torque1st's Avatar
Torque1st
Posting Legend
My Digital VOM will work also. The cheapo engine analyzer Dwell/Tach meters are $35. I have a handheld D/T unit that is about 35 years old that still works.
Here are some other units found with a Google search for dwell tach
http://www.partbuypart.com/store/pro...Product_ID=845 -$30 US
http://gateway.canadiantire.ca/drive...5524442132073_ -$30 Canadian
Here is one on eBay for $5.00 item # 4507874216
Seems like they are easy to find...
Old Dec 4, 2004 | 08:53 AM
mrxlh's Avatar
mrxlh
Well if thats what your using it for, and you don't already have a dial back to zero timing light, you could get one of those with a tach. I bought one for setting timing and idle speed on harleys. Don't konw how I ever got along without it. They are kinda spendy, but well worth it to me.
Old Dec 4, 2004 | 09:20 AM
Crash687's Avatar
Crash687
just thought of something, Fluke make an automotive specific digital meter.
Model 88 and you will need the RPM80 inductive pickup to do rpm.
Old Dec 4, 2004 | 10:28 AM
Aftrmidnite's Avatar
Aftrmidnite
I have a Tif 780 photo tachometer that works well. The only problems I have with it is it won't read the tape on silver colored pulleys, have to paint them flat black, and if you get more than 45* off the reflective tape it looses the signal. You don't hook it up to any thing, just put the reflective tape on what your trying to read. Its great for small engines.
Old Dec 4, 2004 | 12:41 PM
blkhorse's Avatar
blkhorse
I use a mac tool #ettach smartach + wireless tach and spark analyzer.I am not sure who manufacture's it but i have seen them at sears(avail other than on tool truck)real handy tach and kv reader,just hold over engine and it reads spark pulses.works on 2 or 4 cycle 1-10 cyl.it's real accurate too
georgeda
Escape & Escape Hybrid
May 20, 2015 07:19 PM
wendal
Nov 4, 2014 09:56 AM
genevanvoorst
Aug 26, 2014 05:56 AM
39pu
1997 - 2003 F150
Mar 25, 2014 10:28 AM
genevanvoorst
Mar 1, 2014 10:23 AM
