I just did this swap but between a 93 truck and 95 cluster. I found the pin out diagram on this site and simply swapped the necessary wires to account for different pin out positions between the cluster yrs. It works as is should and having a tach is nice. I kept the original speedometer so the mileage and tire size calibration would be correct. The pin out diagrams are here: https://www.ford-trucks.com/forums/1...eedometer.html
Reason: Link
Note that there is more to the difference between 1995 & 1996 than the pin-outs.
There is a difference with the RABS parts in the cluster.
This all was covered in another thread on this Forum.
