Need dyno access
Old Dec 3, 2004 | 12:23 PM
Daryl Hunter's Avatar
Daryl Hunter
The Torqshift will hold the gear in either 3rd, 2nd, and presumable 1st gear.
Third would be the best to use because it is closest to 5th gear which is 1:1.
The problem is that as you go to the lower gears the torque multiplication is even higher and the intertia dynos spin up too fast to allow the motor to really build some boost.
The SAE paper (SAE 2002-01-0887) I mentioned earlier is titled:
"Listening to the Voice of the Customer: Inertia Dyno Horsepower Versus OEM Rated Net Horsepower"
It is quite an interesting read for those really interesting in dyno testing and I'd advise those folks to get a copy. There are a number of areas and concerns when using an intertia chassis dyno. In particular is the mass equivalent (ME) of the dynos roller.
The paper states: "Ideally, for measurement on an inertial dyno, the ME value should be as close as possible to the curb weight of the vehicle. If they are not close, then the rotating elements of the vehicle’s drivetrain will accelerate faster (or slower, depending on the roller ME versus the vehicle weight) than they would in a WOT road test. This would result in a correspondingly larger (smaller) power loss due to inertial losses. Additionally, the variation in roller equivalent mass from one dyno to another is the reason why the same vehicle will deliver different power ratings on different inertia dynos. Each of the three major inertia dyno manufacturers uses a different mass equivalent for its rollers. Representative ME’s for the three largest inertia dyno vendors are approximately 862 kg (SuperFlow), 1,088 kg (Mustang Dynamometer), and 1,633 kg (Dynojet). Before entering into detailed discussion of losses due to different dyno ME’s, it is first necessary to address the difference in losses due to the lack of road loads on the inertial dyno. . . ."
There's lots more good stuff in there.
The bottom line is that intertia dynos while fast and easy to operate don't always give the true results.
Old Dec 3, 2004 | 12:30 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Have we been here before.....
Old Dec 3, 2004 | 12:43 PM
mrxlh's Avatar
mrxlh
Which was what I thought I was translating, if you cannot hold the transmission in the last gear prior to 1:1 which would be fourth, you will not get an accurate reading, nor would you get an accurate reading in 6th because of excessive high rate of spin on the drum (mph) also distorts the numbers.
The mass of the drum stays constant, but there are correction factors for this. I am not saying that an inertia dyno is better than an eddy current by no means, but real numbers can be had by the inertia dyno. It takes a much more knowledgable tuner to tune using the inertia dyno, because of the lack of scenarios you can create with it. A straight up 1 gear roll on is all they (inertia) are good for.
Ryan
Old Dec 3, 2004 | 03:30 PM
IB Tim's Avatar
IB Tim
It will take many more runs/pulls to get the real numbers.....
Neil_E.
Feb 3, 2010 05:41 PM
crapr6
24
May 21, 2008 10:00 PM
tjc transport
New Jersey Chapter
Feb 27, 2007 05:10 PM
roushracing617
Nov 16, 2005 01:40 PM
gtex
32
Aug 19, 2004 03:32 PM
