5.0 timing advance
Old Dec 1, 2004 | 08:24 PM
pageparsley's Avatar
pageparsley
5.0 timing advance
i purchased a 5.0 crate engine and was wondering what i should set my timing advance at. it is the same 5.0 that was put in the 1997 explorers. it has the p-heads. i put a hopped up duraspark ignition on it which was purchased new from performance distributors[founders of davis unified ignition i believe].i have a holley 600 carb and street dominator intake.
Old Dec 2, 2004 | 09:07 AM
jwtaylor's Avatar
jwtaylor
I thought DUI set up the distributor per your cam/combo?
Old Dec 3, 2004 | 09:02 AM
Hourang's Avatar
Hourang
i would just set it at 10deg with the spout disconnected and then adjust it from there, probably around 14-16degrees would be good.
Old Dec 6, 2004 | 03:29 PM
fordeverpower's Avatar
fordeverpower
Dido on what was said by both jw and hourang.
Old Feb 15, 2006 | 04:46 PM
Low55's Avatar
Low55
You only have the "Spout Connector" on Fuel injected motors.
Try 10 BTDC and go from there.
Old Feb 15, 2006 | 05:37 PM
Torque1st's Avatar
Torque1st
Posting Legend
This thread was ~1.5 years old.
dopedawg
Jun 11, 2008 05:45 PM
HENDEL
Jan 6, 2008 09:23 AM
brokenrings
Electrical Systems/Wiring
Sep 17, 2003 02:21 PM
kking1977
Apr 3, 2003 08:29 PM
canabait
Nov 30, 2001 02:33 AM
