9" Rearend
Old Nov 30, 2004 | 08:01 PM
scalezy3b811's Avatar
scalezy3b811
9" Rearend
How would I go about putting a 9" on my '91 F150? How involved is that?
Old Dec 1, 2004 | 08:27 AM
RTM's Avatar
RTM
If you had a 92, I think then you would have an issue with your electronic speedo. But you have a 91 so it will be a direct bolt in. Not sure about the drive shaft length. The 9 inch rear can be had with several different u-joint flanges which affect the u-joint size and the drive shaft length.
I have never done the swap but I know thw 9 inch axle bolts in place. Ford trucks could be had with either the 8.8 and the 9 inch for a few years until the 9 inch was completely done away with.
Old Dec 1, 2004 | 08:31 AM
1982fordf100's Avatar
1982fordf100
Just wondering, why do you want a 9" in there? Your 91 F150 should have the 8.8 already in there which can be as strong as a 9" if you build it up.
Old Dec 1, 2004 | 03:06 PM
scalezy3b811
I want a 9" because it is stronger than the 8.8. I'm about to put a 2003 Harley Davidson Edition engine in my 91 and I need the strength and the posi.
sams6.9
Jul 6, 2017 10:18 PM
Brandon4point9
Oct 28, 2014 07:37 AM
6.9FordMan
Jan 16, 2008 08:01 AM
countryboy29
Oct 3, 2002 06:41 PM
factorystock
Jun 27, 2002 02:38 PM
