1983 6.9 timing
Old Jan 13, 2008 | 05:07 PM
6.9FordMan's Avatar
6.9FordMan
1983 6.9 timing
how do you line up the timing gears for IP on a 6.9 idi? any pics?
Old Jan 13, 2008 | 07:11 PM
PLC7.3's Avatar
PLC7.3
Check out this page........ do you have the front cover off or just the upper timing cover..... http://www.members.shaw.ca/k2pilot/Timing%20article.htm
Old Jan 14, 2008 | 10:59 PM
ford trans tech's Avatar
ford trans tech
if you removed the ip cover and gear and still have the front of the engine together use the harmonic balancer to align the crankshaft timing marks then use something thin and reflective like a table knife stick it down in front of the cam gear and look for two dots should be on two teeth of the cam gear the ip gear has one dot it is located between the two dots on the cam gear
Old Jan 16, 2008 | 08:01 AM
bigbubba87's Avatar
bigbubba87
if you spin the pump over while its off the engine how do you get the pump back in time?
sams6.9
Jul 6, 2017 10:18 PM
BIGPO
May 30, 2013 08:20 PM
Distinctive Dave
Dec 14, 2002 02:32 PM
lazer
Nov 28, 2000 11:44 AM
bgodkin
Nov 10, 2000 07:37 PM
