torque specs on 9in
Old Jun 25, 2002 | 02:31 PM
factorystock's Avatar
factorystock
torque specs on 9in
factorystock:-
How do I find the torque specs needed on a 9 inch?
Old Jun 25, 2002 | 06:48 PM
DIFFMASTER's Avatar
DIFFMASTER
torque specs on 9in
Which specs do you need?
Old Jun 26, 2002 | 12:28 PM
DIFFMASTER's Avatar
DIFFMASTER
torque specs on 9in
Old Jun 27, 2002 | 08:56 AM
factorystock
torque specs on 9in
>factorystock:-
factorystock
I am going to try and rebuild my first 9 in. We race dirt roundie rounds. I don't want to rely on others and their time schedules if I can do it myself. I gues I need all the torques for every bolt in the thing. Thanks for your time and response.
factorystock
torque specs on 9in
factorystock
Old Jun 27, 2002 | 08:57 AM
factorystock
torque specs on 9in
factorystock
Old Jun 27, 2002 | 01:42 PM
DIFFMASTER's Avatar
DIFFMASTER
torque specs on 9in
If running a solid collar in place of the crush sleeve, torque pinion nut to 225 ftlbs, if using a crush sleeve, there is no preset torque, you tighten the nut down until you have proper pinion preload. Ring gear bolts are 70 ftlbs, main caps are 80 ftlbs. Pinion support bolts are 45 ftlbs. Adjuster lock bolts are 12 ft lbs. Good Luck
Old Jun 27, 2002 | 02:38 PM
ronbo862's Avatar
ronbo862
torque specs on 9in
robbv
2009 - 2014 F150
Sep 20, 2017 12:15 PM
aj64f100390-292
Nov 1, 2016 08:45 PM
F150-4-Life
May 30, 2010 12:05 PM
BuckinBroncoII
Bronco II
Jun 25, 2004 03:54 PM
Polkat
Nov 27, 2002 10:42 PM
