My ignition key has been stuck occasionally when I shut the engine off. I can not get the key switch to rotate back to the position to allow key removal. This does not relate to steering wheel position but seems to relate to the shift lever being positioned properly in park. I must jiggle the shift lever while in park to free up this key switch. It does not happen all the time. Anyone else have this problem and is there a fix, adjustment,or is it a user problem?
No help here, just ditto on same problem.
'04, F250, 5.4, auto, 2WD
Don't have difficulty turning key, but at times it just won't come out in a peaceful manner, and no, it's not a weather matter, temp doesn't effect.
Truck not parked on incline or any other factor that would bind steering linkage/components.
