Transmission Fluid Change
Old Nov 27, 2004 | 09:36 AM
l.stull's Avatar
l.stull
I was wondering what anyone thinks about yhe machine trans flush vs. the good ol drop the pan,change the filter procedure? Also what fluid would u recommend ? thanks all
Old Nov 27, 2004 | 10:41 AM
DaBigTow's Avatar
DaBigTow
The machine flush doesn't change the filter or clean out the particles trapped in the pan. Drop the pan. As for fluid, I'm switching to Mobil 1 synthetic on my next change.
Old Nov 28, 2004 | 08:33 AM
slc10844's Avatar
slc10844
I always drain the pan, clean and inspect, replace the filter, add 4 quarts of fluid, then use the flush machine. The machine isn't necessary to do a flush, it just makes it easier to do. We use Synergyn Super Shift synthetic ATF. Synthetic ATF will tolerate heat better and allow extended service intervals.
Old Nov 29, 2004 | 07:01 AM
Casey's Avatar
Casey
Here is how you can do it yourself:
Trans Fluid Change
Old Dec 11, 2004 | 06:44 AM
rirwin's Avatar
rirwin
I'm about to flush mine, but have a question about this procedure. If you pump out the fluid from the return line at the tranny, isn't there a period of time that your running the engine/tranny with the pan empty? This doesn't do any damage?
Old Dec 11, 2004 | 07:11 AM
slc10844's Avatar
slc10844
There should still be enough residual fluid on the internals to provide sufficent lubrication for a period of time. As long as you shut down when you start to get air, you won't have any problems.
Old Dec 11, 2004 | 07:33 AM
rirwin's Avatar
rirwin
Much thanks! One more 'dumb' question. When you refill the pan after pumping it out, do you start it up with the hose still in the bucket, or do you re-connect the cooling line to start it up?
Old Dec 11, 2004 | 07:43 AM
slc10844's Avatar
slc10844
You only remove the hose and reconnect when you have completed the flush procedure. Until then just leave the hose in the bucket. It simplifies things if you have a helper up top to start and stop the engine.
Old Dec 11, 2004 | 07:47 AM
rirwin's Avatar
rirwin
Thanks again. I'd hate for my ignorance to cost me a tranny.
Old Dec 11, 2004 | 08:50 AM
slc10844's Avatar
slc10844
Better safe than sorry. Read and follow the directions, take your time and you shouldn't have any problems.
Old Dec 11, 2004 | 08:57 AM
kilapapipa's Avatar
kilapapipa
I used the method described in the post above a couple of weeks ago and it worked like a charm. I did not change the filter this time so it went really fast.
NOTE: get a tranny filler funner if you do not have one. You have to hook it up to each bottle but makes the job clean.
hedhntr
May 2, 2012 10:25 AM
rkloehn
Modular V10 (6.8l)
Nov 11, 2011 07:44 PM
crazer42
Mar 26, 2009 03:54 PM
Beaned
Aerostar
28
Sep 14, 2008 10:47 PM
cobarjet
Oct 17, 2007 11:36 AM
