Engine block heater
Old Nov 23, 2004 | 06:46 PM
pg100man's Avatar
pg100man
Question Engine block heater
Just got a 2004 psd,Heading up to Oregon For Turkey Day,Went to find cord for block heater,I found it but boy is it short! Anyone know where this cord should come thru the grill ?Right now I can get it out the right tow eye about an inch,but if you let go of it it pulls back into the abyss.any thoughts ??
thanks !!
Old Nov 23, 2004 | 06:56 PM
SBV45's Avatar
SBV45
I think it has a tie wrap on it.
Old Nov 23, 2004 | 08:02 PM
pg100man's Avatar
pg100man
Yup,cut the tie wrap already.I was hoping to get it out a little more.Its hard to get my big mitts up in there !
Old Nov 23, 2004 | 08:17 PM
Casey245's Avatar
Casey245
Tie it off to your tow hook with a black tie works well for me
but first you must cut the loop of wire free from a plastic clip up in the grill ITS HARD to get to.
Old Nov 24, 2004 | 12:29 AM
rstokes's Avatar
rstokes
engine block heater
I had the same problem with the cord being too short. I wound up going to the local Home Depot and buying the materials (14ga.wire and end connectors) and making an extension cord about 10" long. I leave it plugged in and tuck it behind the grille when not in use. Be sure and not forget to drape the electrical supply cord over your driver's side mirror when using the engine block heater so as to not depart with the cord still plugged to your PSD. Someone else posted this tip here and it sure has saved forgetful me.
Old Nov 24, 2004 | 07:16 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
Be sure to check out the 6.0 Bible…..great reading
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
http://www.backglass.org/duncan/ps60_manual/
…. In the upper right hand corner of your screen check this out PARTS SHOP for all your “trucking” needs
Must read
http://www.clubfte.com/users/monsta/SuperDutyFAQ.html
https://www.ford-trucks.com/forums/s...d.php?t=303583
Enjoy FTE
stydel311
Jan 24, 2014 04:25 PM
joe f350
Dec 3, 2010 07:36 PM
drivembig
17
Jan 11, 2010 04:36 AM
WALJON
19
Dec 12, 2009 09:10 PM
oneway
Feb 14, 2009 02:50 PM
