Need help identifying engine
Old Nov 23, 2004 | 10:28 AM
daviddennis's Avatar
daviddennis
I need to figure out what engine I have (460, 429, 390, 360 ?). There is no engine tag. It is not on the valve cover. The only number I can find is on the engine block on the passenger side #94159. I would appreciate any info.
Old Nov 23, 2004 | 10:50 AM
Mike G's Avatar
Mike G
First off, welcome aboard!
Secondly.. Is the motor still in the original vehicle? If so, what year and vehicle is it? If not and it is just a motor, there are several things we can look at to identify it. How many valve cover bolts does it have? Where is the thermostat housing, on the block (water pump housing) or on the intake manifold? Does the intake manifold extend under the valve covers?
A few questions to answer and we will see what you got, --Mike
Old Nov 23, 2004 | 11:29 AM
daviddennis
Help identifying engine
Mike,
The engine is not in a vehicle so I don't know what year it is. I will have to go home and look at the engine to answer your questions. I will post the answers tomorrow. Thank you so much for replying.
David
Old Nov 23, 2004 | 01:30 PM
fordeverpower's Avatar
fordeverpower
The are 5 valve cover bolts for an FE motor which would be the 360/390 etc. The thermostat housing is on the intake manifold.
THe 351m/400 have 6 valve cover bolts and the thermostat is on the front of the block
The 429/460 have 7 valve covers bolts.
Its a good idea to get the casting number off the intake such as d4ae-9015 for example. The important part is the d4ae but it could be anything this is just an example.
first letter is decade
c=60s
d=70s
e=80s
f=90s
The second thing is the year of the decade!
d4 is 1974!
Old Nov 24, 2004 | 09:58 AM
Mike G's Avatar
Mike G
you have mail...
Keep in mind the 429 and 460 were based on the same block. You will want to check in with the crew on the 385 series forum to find out how to tell the differences (it's in the stroke I believe).
--Mike
Old Nov 29, 2004 | 06:33 PM
joestang's Avatar
joestang
hi daviddennis im sorry to tell you this but you stated that the 351m/400 had 6 valve cover bolts ...but they have eight
Old Dec 6, 2004 | 02:22 PM
fordeverpower
Thats my bad! The 351m/400 have 8 bolt valve covers. The funny thing is I had spent the last month working on a 351c and had the valves cover on and off 3 times or better.
chukar
Jul 24, 2017 10:55 PM
khadma
Jul 4, 2017 07:56 PM
02GrayPowerStroke
1997 - 2003 F150
Feb 8, 2017 04:08 PM
Johno.h
15
Oct 5, 2016 02:23 AM
Kev1180
Large Truck
Sep 2, 2015 03:56 PM
