Sponsored by: Auxito
4.6 5.4 wireing harness
Old Feb 2, 2017 | 12:58 PM
02GrayPowerStroke's Avatar
02GrayPowerStroke
Are the 4.6L engine wiring harness interchangeable with the 5.4L engine? I need the whole engine wiring harness. I found one but it has the 4.6L engine.
Thanks Chris
Old Feb 2, 2017 | 03:47 PM
Shadow351's Avatar
Shadow351
No, Depending on the year, the ignition systems are different. Parts might be interchangeable but the entire harness will most likely not, they even vary from year to year with the same engine.
Old Feb 2, 2017 | 03:55 PM
02GrayPowerStroke
Crap o'la Thanks
Old Feb 2, 2017 | 04:30 PM
02GrayPowerStroke
What other vehicle will work on the 99 5.4? Expedition?
Old Feb 2, 2017 | 10:21 PM
Shadow351's Avatar
Shadow351
hmm, having trouble finding that information for sure but it looks like the engine harness is the same for the 5.4L Expy from 99-02. Do you have a harness to look at? If so does it have a part number tag on it (should be near the bulkhead connectors)? Why are you replacing the harness (is it damaged)? Might be easier to repair if the damage isn't too severe.
Edit: Does this look like the harness you need? http://www.ebay.com/itm/99-00-01-02-...xYYYQB&vxp=mtr
Old Feb 3, 2017 | 09:03 AM
02GrayPowerStroke
99 00 01 02 Ford Expedition 5 4L Engine Wiring Harness 1L1T 12B637 P260G | eBay
Here is the pn ford gave me XL3Z12A581FA
Old Feb 3, 2017 | 10:16 AM
Shadow351's Avatar
Shadow351
This kind of information is difficult to find so the dealer information is probably your best bet. The info I have says the XL3Z prefix is for an F150/F250. The F150/F250LD shared alot with the Expedition but I don't know if the engine harnesses are the same or not. The 12A581 is the main Engine Harness PN. My information states that the 99 Expedition prefix is XL1Z but my search for XL1Z-12A581 has been fruitless.
Old Feb 3, 2017 | 10:37 AM
02GrayPowerStroke
I have spent weeks looking for this part. This is the only one i have found new or used. There is not any ford dealers in the usa that has one
Old Feb 3, 2017 | 10:48 AM
Shadow351's Avatar
Shadow351
yea, unfortunately they discontinue manufacturing parts after about 10 years. It's really difficult to find Genuine Ford parts for my 94 Mustang for reasonable prices.
Do you have a harness and it is damaged or do you not have a harness at all?
Old Feb 3, 2017 | 11:45 AM
02GrayPowerStroke
The harness is totally burned up from the exhaust manifolded
Old Feb 3, 2017 | 04:28 PM
02GrayPowerStroke
I cant seam to find it for sure but XL3Z12A581FA harness does run down to the transmission right?
Old Feb 4, 2017 | 08:45 PM
Shadow351's Avatar
Shadow351
the transmission harness is a separate harness, pn 15525 (the rest of the PN depends on the transmission you have and if it is 4x4 or 4x2).
What all does the harness in question plug into?
15525 appears to plug into 12A581 under the starter relay on the firewall, and connects to these devices:
-Transmission range sensor
-Output speed sensor
-Transmission solenoids
-downstream O2 sensors (behind catalytic converters)
-vehicle speed sensor
-transfer case (if equipped)
Old Feb 8, 2017 | 04:08 PM
02GrayPowerStroke
Thanks for the great information!! What is the full PN for the harness? What would your suggestion on locating one?
berriault
1997 - 2003 F150
31
Dec 23, 2021 05:35 PM
BURNSTOUGHFORD
1997 - 2003 F150
Apr 10, 2008 06:24 PM
sheldon
1997 - 2003 F150
Oct 25, 2002 06:51 AM
Yellardawg
1997 - 2003 F150
Mar 19, 2002 04:36 PM
