Scan Codes Help Needed
Old Mar 1, 2002 | 06:07 PM
BobFlowers's Avatar
BobFlowers
87 Ranger 2.3 Auto, hookup scan code reader, all equipment off, (after engine is warm), plug in scanner, put switch on HOLD, turn ignition switch ON (not run/start), scan code reader beeps, no codes are generated, waited 2 hours, supposed to be 10 sec to 1 min before codes generate, anyone have any idea where to start to verify what might be wrong?
Also, worse case scenerio, if I need a new ECU, where to get? AutoZone wants $94
Part# E7TF-12A650-J1A
This may be my issue(s) as to why I'm not seemingly running correctly??
Old Mar 1, 2002 | 07:28 PM
Hank85713's Avatar
Hank85713
If you are using (which it sounds like) a commercial reader, check the battery (9v) which makes it work. On the one I have you are supposed to be on the audio side and hold for initial hookup. When key is turned to on, go to test from hold.
Old Mar 1, 2002 | 08:27 PM
desperado_18_2000's Avatar
desperado_18_2000
sun622
Escape & Escape Hybrid
Jul 8, 2011 06:58 AM
redman84
Sep 27, 2010 06:36 AM
Jaaaaaaackman
Aug 16, 2007 09:13 PM
joners
Feb 8, 2006 05:26 PM
Paxcam
Feb 4, 2003 11:41 PM
