Sponsored by: Real Truck
Keypad Removal
Old Nov 17, 2004 | 01:40 PM
mizzitch's Avatar
mizzitch
Keypad Removal
Does anyone have any suggestions on how to remove the keypad entry piece that can be bought off ebay or from the dealer? It uses some strong double stick tape. I put it on my 1999 SD, but now I have a remote start system, so the keypad is useless.
Old Nov 17, 2004 | 02:15 PM
etcetera's Avatar
etcetera
Try a piece of dental floss to cut through the sticky backing.
Eric
Old Nov 17, 2004 | 02:21 PM
Autobahn F-250 Lariat's Avatar
Also try fishing line
Old Nov 17, 2004 | 02:23 PM
mizzitch's Avatar
mizzitch
Is there a good solvent that will take off the sticky residue w/o damaging the paint? I was thinking maybe just rubbing alcohol.
Old Nov 17, 2004 | 02:32 PM
rubbing alcohol and elbow grease or googone i believe it is called
Old Nov 17, 2004 | 05:41 PM
etcetera's Avatar
etcetera
Be sure to test any solvent somewhere where it isn't obvious, a door jamb maybe. Some stuff is sold around here called goof off. Similar name to googone, but probably not related at all. If you could buy Goof Off in gallon containers it'd be a convenient way to strip the paint off a car.
Eric
La Habra, CA
Old Nov 17, 2004 | 06:56 PM
a12play12's Avatar
a12play12
Hey everyone,
Try 3M adhesive remover, its made fo removing adhesive frome paint finishes.
ALWAYS, ALWAYS, try it in an inconspicuous place first.
Good Luck, R.
Old Nov 17, 2004 | 08:41 PM
fireman28's Avatar
fireman28
Heat it with a hair dryer and use a floss doubled. If you have some sort of solvent use it at the same time. It will make it easier.
Old Nov 18, 2004 | 06:28 AM
JimRietz's Avatar
JimRietz
So what happens if you lock your keys in the truck? It might be pretty useful in that case.
Jim
Old Nov 18, 2004 | 07:36 AM
mizzitch's Avatar
mizzitch
The remote start works on a different frequency than the keypad(which just sticks to the door and sends a signal like the factory keyless entry - it is not the hard wired keypad that comes from the factory). If I lock my keys in I have a spare hidden under the truck.
Old Nov 18, 2004 | 10:28 AM
skilawyer's Avatar
skilawyer
another vote here for the fishing line. as for the sticky stuff, wd-40 works with some adhesives. if not, a clay bar will work.
F350 king ranch
Sep 1, 2013 04:06 PM
stuart1031
2004 - 2008 F150
Feb 21, 2010 08:26 PM
kwhite
2009 - 2014 F150
Feb 9, 2010 10:17 PM
partsBoy
Electrical Systems/Wiring
Oct 1, 2007 07:03 PM
3KIDDAD
Jan 17, 2007 09:13 PM
