Sponsored by: Real Truck
Difference between 250 and 350?
Old Nov 18, 2004 | 10:25 AM
Duksrule's Avatar
Duksrule
Just priced a new truck on the NET. A 350 is about $1500 more than a 250 for the same truck. I thought the only difference was the size of the block under the rear spring. Aren't the otherwise the same truck? That block must be made of gold for $1500. Guess I will be getting another 250.
Old Nov 18, 2004 | 10:30 AM
Autobahn F-250 Lariat's Avatar
the 350 gives you more payload capacity
try the search button must be a hundred threads on this very subject
Old Nov 18, 2004 | 10:35 AM
Duksrule's Avatar
Duksrule
sure type F-350 into the search and read all 1200000000 posts that pop up.
Old Nov 18, 2004 | 10:44 AM
well there you go you have a lot of reading to do
