Desktop Dyno Please....
Old Nov 16, 2004 | 08:33 PM
Annihilator's Avatar
Annihilator
Here is the engine and drivetrain...
Ford 390 bored and honed .060 over (401.2 c.i.)
Edelbrock Performer RPM intake
Holley 600 cfm vac. secondary (going to put a Street Avenger 670 on it in the near future)
Speed-Pro forged flatop with 4 valve reliefs (don't know what my deck clearance is for sure but piston top almost came dead even with top of bore)
Fel-Pro .041 compressed thickness head gasket (composition type)
Engine has 198 to 200 p.s.i. cranking pressure with current cam and should be right at about 10.1:1 or 10.5:1
Current cam is Edelbrock Performer-Plus (which I think sucks) 194/204 duration @.050" 460/480 lift
C8AE-H and D-2TEAA heads with polished chambers, blended bowls, polished exhaust runner and took out smog bump in roof of exhaust runners (68 to 71 cc chambers)
Dynomax ceramic coated headers with 2 1/2 pipes and 18 inch glasspacks
C-6 transmission
3.50 gears
Can't decide on a different cam yet so far the ones I am looking at are the following
Crane 343941
Comp Xtreme Energy 218/224 duration @.050 .513/.520 lift
Lunati 223/223 Dur. @ .050 .514/.514 lift
Lunati 221/221 Dur @.050 .533/.533 lift
Engle 225/225 Dur. @ .050 .510/.510 lift
I can't seem to find Erson's site on their FE cams but if anyone can find them and run some comparable ones to the ones listed above, I would appreciate it. My engine also has adjustable rocker arms
Thanks to anyone who will do this,
JC
Old Nov 16, 2004 | 09:15 PM
rusty70f100's Avatar
rusty70f100
Valve events man, I need valve events! I need IVO, IVC, EVO, and EVC to run 'em. Seat specs are better than .050".
However, I can run the 941 since I have that on file. You get 388hp @ 5000rpm, and 447ft-lbs @ 3500rpm. Nice flat torque curve.
Does it ping with that performer-plus cam? It seems like you've got quite a bit of compression for it.
Edit: I do have that comp cam on file. It'll get you 358hp @ 4500rpm, and 463hp @ 2500 and 3000rpm. Fairly flat torque curve on the low end.
Old Nov 17, 2004 | 11:22 AM
cleanLX's Avatar
cleanLX
any chance you have the comp cams 268H (part no. 33-224-3) cam on file?
if so, I'd appriciate a desk top dyno as well...
Old Nov 17, 2004 | 03:51 PM
cleanLX's Avatar
cleanLX
just in case you can run that cam, here's the rest of the simple build.
390 0.040 over.
stock 2bbl intake.
Holley 500 cfm 2bbl (1/2" phenolic spacer... whatever that's worth?) tuned to 12.8:1 a/f.
Pistons are cast Summit specials... c/r came out to 9.5:1.
stock crank and rods, full rotating assembly balanced.
cam as above w/ recomanded springs.
C6AE-R heads milled, with blended bowls, basic port cleanup, cobra jet valves, 3 angled. ( guessing similar 68 to 71 cc chambers).
stock shaft mount rockers.
stock logs, 2-1/4" Y pipe, into single 3" exhaust.
petronics, blaster 3
and, for intrest sake, what difference would 1-3/4" dia. 27" long, headers make, with, 3" collectors and still into a single 3" exhaust?
and, thanks in advance to anyone who has the time for my nonsence.
Old Nov 17, 2004 | 07:09 PM
Annihilator
Yes it can ping with that cam if you have the timing to high and don't run 91 octane. I can't get the timing down to where I would like with the stock dizzy (total gets to be to high) so I would need to recurve the dizzy which I may do with a new one but am leaning heavily toward a Mallory with vac. advance. I will try to get you the valve events on those cams.... Anyone find Ersons website? It should be under Mr. Gasket.com
Old Nov 17, 2004 | 07:23 PM
rusty70f100
CleanLX, here's your numbers: 270hp @ 4500rpm, and 390ft-lbs @ 3000rpm. The torque is basically flat from 2000 to 4000rpm.
With headers you're up to 322hp @ 4500rpm, and 431ft-lbs @ 2000rpm. The torque drops slowly off after that.
-cough- biggercam -cough-
Annihilator
Old Nov 17, 2004 | 07:33 PM
Annihilator
I found the Erson cams but it doesn't have the valve events, maybe someone here knows them or can find them....
The cams I was wondering about from them are the following
part # E241021 M/P2 has the following 292/310 advertised dur. 214/226 dur. at .050 .523/.539 lift 114 degree lobe center
part # E240321 Hi-Flow AH has the following 284/284 adv. dur. 220/220 dur. @ .050 .551/.551 lift 112 degree lobe center
Both of these cams have 4 degrees advance ground into them
Old Nov 17, 2004 | 07:34 PM
Annihilator
Does any of that help?
Old Nov 17, 2004 | 07:48 PM
Annihilator
What about the following Comp cams
Dual Energy 33-208-3 275/285 adv. duration 219/232 @.050 dur. .515 .541 110 degree lobe seperation
Xtreme Energy 33-248-4 274/286 adv. duration 230/236 @.050 dur. .562 .565 110 degree lobe seperation
Old Nov 17, 2004 | 07:49 PM
rusty70f100
I'm sorry but it doesnt. I still dont know where the valves open and close.
Call 'em up and ask. If they're serious about selling you a cam they'll tell you.
Old Nov 17, 2004 | 07:57 PM
rusty70f100
I already have the Comp 33-208-3 cam on file, you're at 383hp @ 5000rpm, and 445ft-lbs @ 3500rpm.
The 248 I dont have numbers for yet.
Old Nov 17, 2004 | 09:43 PM
Annihilator
I sent and a question to Engle Cams and hopefully I will hear from them soon. I wish the cam of theirs that I was looking at had more lift but if we get the valve events I guess we will see what it does. I also sent some info to Lazer cams.
Old Nov 17, 2004 | 09:52 PM
Annihilator
Lazer has 2 cams that caught my eye....
part#2700140 and 2800140
Don't know if you have the specs and valve events to these but if not I will try to call or email them for the valve events and the seat to seat specs.
I sent an email to Erson to get the valve events and the seat to seat specs on the 2 cams of theirs I was looking at.
Old Nov 17, 2004 | 10:02 PM
cleanLX's Avatar
cleanLX
Wow!
Thanks a million.
I'd never of imagined headers would be such a significant gain.
431 at 2000 makes me all warm and fuzzy...
Now, where'd I put my Christmas list?
-cough- [i[ya... I know[/I] - cough-
Funny, I had the 270 in it on the initial build, and, the friggin' motor ate it.
Parts store did not have anymore 270's, and, I wanted it done now dangit, so, in went the 268... Live and learn...
That was before I knew of this site... I likely would be running something one of you fella's would've recommended otherwise.
