Desktop Dyno Please....
Old Dec 23, 2004 | 08:52 AM
  #46
whd507's Avatar
whd507
Thanks!! I'll check that out.
Old Dec 23, 2004 | 11:48 AM
  #47
rusty70f100's Avatar
rusty70f100
What DD2k says, is that with the 801 you lose quite a bit of low end torque for a minimal gain of HP up top.
Get me an email address and I'll send the results.
Old Dec 23, 2004 | 01:58 PM
  #48
Annihilator's Avatar
Annihilator
I will have to set a new one up. What do you recommend for this? I have the DynoSE program and I am admittedly not real experienced with it. I am getting different numbers on hp and torque output with the 2 Erson cams I gave you valve events for. I am guessing that it has something to do with my cylinderhead selection. Maybe it isn't as good of a program....
Old Dec 23, 2004 | 03:03 PM
  #49
Annihilator
Kurt, I called Engle and got the valve events for 3 of their cams. Here we go...
Part # 3110H lift @ .050 intake-.509 exhaust-.509 duration @ .050 214/222 112 degree lobe center, Valve events- Int open= -2 / Int close= 36
exh open= 46/ exh close= -4
Part # 3172H lift @.050 .510/.510 Duration @ .050 227/227 110 degree lobe center
Valve events- Int open= -6 intake close= 41
Exh open= 46 Exh close=1
Part # 3174H Lift @ .050 .519/.519 Duration @ .050 232/232 110 degree lobe center
Valve Events- Int open=7 Int close=46
Exh open=47 Exh close=6
Hope that cover everything you need for those if not, tell me what I may have missed.
Thanks,
JC
Old Dec 23, 2004 | 08:50 PM
  #50
Annihilator
Kurt, I can't get my DynoSE program to plug in the Engle cam specs that have the -2 intake open and -4 Exhaust closes then the -6intake opens. A negative number seems wierd in the first place....???
Old Dec 23, 2004 | 10:25 PM
  #51
rusty70f100
First, send me an email with whichever email address you can receive attachments on.
Second, those are the valve events at .050" lift. While I can use 'em, the seat events will produce more accurate results.
Old Dec 24, 2004 | 09:53 PM
  #52
Annihilator
I will have to call Engle again. I will try and set up an email address tonite. Kurt, I talked on the phone with a guy at Lazer Cams and he had some real interesting information and advice. How's this one do?
Duration @ .050 225/230 Lift 552/566 Lobe Seperation - 108, with 104 intake centerline Valve Events- Int. Open = 33.5 Int. close = 61.5
Exh. Open = 72 Exh. close = 28
This cam is supposed to pull hard from 1700 to 5500 and have an obvious lope in the idle (900-1000 RPM)
Old Dec 24, 2004 | 10:46 PM
  #53
rusty70f100
I compared this cam (the Lazer) to the 941. You lose a little hp compared to the 941. With the lazer you get 383hp @ 5000rpm, and 447ft-lbs @ 3500rpm.
I'm beginning to think that the 941 cam was designed specifically for DD2k.
Old Feb 14, 2005 | 10:42 AM
  #54
Annihilator
Sorry to resurrect this thread but I figured it would be easier for Kurt. I called Lunati and got the valve events on this cam. It is a flat-tappet hydraulic.
Intake opens-8.5 Exhaust opens-44.5
Intake closes-36.5 Exhaust closes-.5
The cam has .550 lift @.050 and has 225/225 duration, 108 lobe seperation and 104 intake centerline.
Could you run that on my build Kurt?
Old Feb 14, 2005 | 10:54 AM
  #55
rusty70f100
Alright, here's the results with the Lunati cam:
386hp @ 5000rpm, and 440ft-lbs @ 3500 and 4000rpm.
Old Feb 14, 2005 | 08:56 PM
  #56
polcat's Avatar
polcat
Annihilator, look at a company called Deltacams.com I just order a custom grind cam from them today. I called Lazer cams, Camresearchers and Deltacams and they cam up with the best grind and produced the most power. However since I have a dexktop dyno I tweaked the specs some and fround even more power. I will tell you from what i have seen the 110 lode seperation and 106 centerline will give the most power. Good luck!!
Old Feb 15, 2005 | 01:11 PM
  #57
Annihilator
Well, I may do that, but I just ordered a cam from Lazer along with their recommended springs, retainers, and locks. I allready have a new set of lifters (Crane's) that I bought when I built my engine and never used and Lazer said to go ahead and use them. Then I ordered a TCI Streetfighter C6 from Summit, along with a TCI Saturday Night Special Torque Converter and Moroso U-Joint girdles. Had to order the Auburn Gear Pro Series limited slip diff. from Jegs though (Summit didn't have it). Now I am really beginning to think that all I am ever really going to have in life is this old Ford pickup!
Old Feb 15, 2005 | 05:00 PM
  #58
Annihilator
I can't find their website. www.deltacams.com brings up a search site.
Old Feb 15, 2005 | 07:17 PM
  #59
polcat's Avatar
polcat
Sorry it is www.deltacam.com
Old Apr 26, 2005 | 06:50 PM
  #60
Tmod700's Avatar
Tmod700
Here is a cam that I had specd for me from Motor Machine & Supply.
Overlap=44
Cam Advance=4
L.C.A. 107
Intake Duration=258
Exhaust Duration=257
Intake Centerline=103
Intake Gross Lift=.533
Exhaust Gross Lift=.521
Intake Opens=26
Intake Closes=-52
Exhaust Opens=-60
Exhaust Closes=18
This is for my truck and towing applications but give it shot and see how it works with your combination on Desktop Dyno or DynoSim.
