Desktop Dyno Please....
Old Apr 27, 2005 | 12:41 PM
  #61
cleanLX's Avatar
cleanLX
from what little I know, 'er think I know, that looks like a nice truck cam.
i'm interested to see what rusty finds out.
Old Apr 27, 2005 | 12:51 PM
  #62
rusty70f100's Avatar
rusty70f100
Originally Posted by Tmod700
Here is a cam that I had specd for me from Motor Machine & Supply.
Overlap=44
Cam Advance=4
L.C.A. 107
Intake Duration=258
Exhaust Duration=257
Intake Centerline=103
Intake Gross Lift=.533
Exhaust Gross Lift=.521
Intake Opens=26
Intake Closes=-52
Exhaust Opens=-60
Exhaust Closes=18
This is for my truck and towing applications but give it shot and see how it works with your combination on Desktop Dyno or DynoSim.
Those specs seat to seat or .050"?
You really should have started your own thread instead of dragging this ancient one back up. Not that that's a problem...
Now that I've been volunteered, I dont like that cam. The duration is about right for stock type motors in trucks, but you should be running a dual pattern cam with the exhaust having bigger duration. This is because the intake flows more than the exhaust in these motors.
Old Apr 27, 2005 | 01:03 PM
  #63
Tmod700's Avatar
Tmod700
I wasn't asking that you run it for me. I was just offering another option for a comparison if anyone wants to try it.
Before saying anything about the cam just give it a try and see what you come up with.
Those figures are seat to seat.
Tmod
Old Apr 27, 2005 | 01:10 PM
  #64
rusty70f100
Sure, I'd be happy to give it a try with desktop dyno. It wont really take me too long to plug it in. What's the rest of the build?
Old Apr 27, 2005 | 06:29 PM
  #65
Tmod700's Avatar
Tmod700
Here are my specs
Cylinder= 8
Bore= 4.090
Stroke= 3.78
Cyl Heads= Edelbrock Perf RPM
Head Flow data:
Pressure Drop @ 28.0
Intake--------Exhaust
.100=88------.100=64
.200=153-----.200=113
.300=195-----.300=148
.400=233-----.400=171
.500=265-----.500=183
.600=270-----.600=200
Dual Plane With 600 CFM
Small Tube Headers W/Mufflers
Cam Info
Hydraulic @ seat to seat
Int lift .531
Exhaust lift .520
Int Duration=258
Exh Duration=256
107 L/C
Int open @ 26.0
Int closes @ 52.0
Exh opens @ 59.0
Exh closes @ 17.0
Well that is about it.
Old Apr 27, 2005 | 06:42 PM
  #66
rusty70f100
Compression ratio?
Old Apr 27, 2005 | 06:59 PM
  #67
Tmod700's Avatar
Tmod700
Ooops Sorry!!
9.56
Tmod
Old Apr 27, 2005 | 07:35 PM
  #68
rusty70f100
Ok, Desktop Dyno is showing 338hp @ 4500rpm, and 453ft-lbs @ 2000rpm.
Old Apr 27, 2005 | 07:44 PM
  #69
Tmod700's Avatar
Tmod700
Thank You!
What version of DD are you running?
Tmod
Old Apr 27, 2005 | 09:10 PM
  #70
rusty70f100
I'm running Desktop Dyno 2000. I know there is a newer version, but I'm too cheap to buy it.
2.5itim
18
Sep 6, 2016 01:53 PM
jerg_064
24
May 28, 2009 04:19 PM
4doorford
Feb 15, 2008 07:59 PM
highboy 74
Aug 19, 2005 07:21 PM
Jobless
Feb 11, 2004 11:41 PM
