97 ex with 4.6L Check engine light code P0171 "Lean"
Old Nov 15, 2004 | 02:46 PM
YostRH's Avatar
YostRH
I have read several threads aboutP0171 and 174 engine codes and have seen allot of good info, but I still have issues.
It all started several months ago with Fuel too rich P0172 bank one and two. The shop replaced the fuel rail regulator the check engine light was off for a week and a half. Light came back on! and engine codes were now lean P0171 bank one and two, took it back to the shop they said MAF sensor for $430. I promptly pick up the vehicle and replace that myself for $87. several days later the check engine light is now back on. I have the PVC to intake hose on order and will have that on Tuesday (although the current one looks OK) 3 months ago I replace the upper O2 sensors, and fuel filter, air filter. Strange thing is, idle is fine, towing is fine, acceleration is fine, same gas mileage. Maybe when I get the new hose the culprit is the PCV valve although is seems that it is working fine.
I am at a loss~~~ I have 118k runs and looks great if I can't fix it. --> my wife wants a new 05 expy PLEASE HELP
Old Nov 26, 2004 | 01:48 PM
YostRH's Avatar
YostRH
Just to update ~ I recieved the PVC to intake hose from the dealer with no luck 4 days later the Check Engine light is back on! I am running out of parts to replace!??? Any Ideas?
Old Dec 21, 2004 | 07:44 PM
YostRH's Avatar
YostRH
Cool Still lean with CEL on
Still cannot get rid of the pesky CEL and other ideas would help
Old Dec 22, 2004 | 09:53 AM
The Besh's Avatar
The Besh
If your truck is running OK, drive it and forget about the CEL. In time, the CEL will go out. That doesn't say much for all the money you've spent trying to fix a problem that doesn't exist.
The Besh
bismic
Aug 10, 2015 10:35 AM
cr295
Jul 31, 2015 08:12 AM
Keny1
New Member Introductions
Oct 25, 2013 10:59 AM
Alanok
1983 - 2012 Ranger & B-Series
Apr 11, 2005 11:16 AM
mr p
General Automotive Discussion
Jun 26, 2004 07:25 PM
