1978 - 1996 Big Bronco
Remote starter - looking for simple, reliable
Old Dec 19, 2004 | 05:04 PM
MinnManBroncoFan's Avatar
MinnManBroncoFan
bottom of the steering column were the wires come out need to splice into them in that area
Old Dec 19, 2004 | 05:36 PM
kaised's Avatar
kaised
ok, so I don't have to actually get near the ignition switch? I saw a number of wires below the column but wasn't sure if they were the right ones since they were plugged into a grey harness of some sort. There seemed to be multiple yellow wires, which should be the 12v contant lead - does it matter which one I use? Any help would be appreciated.
Old Dec 20, 2004 | 06:07 AM
Big Daddy J's Avatar
Big Daddy J
Check this site out if you're having problems with finding the wires.
http://www.icdynamics.com/
Look for the section 'wire guide search' and you can enter in vehicle info and it will give you a wire guide. Very helpful
Old Dec 20, 2004 | 09:23 AM
kaised's Avatar
kaised
Are you sure that is the site? It doesn't seem to want to work.
Old Dec 22, 2004 | 01:57 PM
scootin's Avatar
scootin
I just installed a DesignTech Autocommand (model 2100 maybe?) remote starter last night. Bought it off ebay for $30.00, new in package - the same one they sell at Autozone for $85.00. Not a bad install, but splicing the wires is a bit tedious - not much slack in the wires, or room to work. It's a pretty slick setup - no unnecessary bells or whistles...just a remote starter. Works great. I just need to finish routing the antenna through the A-pillar and to the windshield and I'm finished.
Old Dec 22, 2004 | 03:38 PM
Big Daddy J
yeah...that's the site. Just used it today installing a remote start in a 00 Monte Carlo. Site must have been down whenever you tried it.
Apocalypse
Jan 25, 2016 05:08 AM
65fsbk
May 18, 2014 11:39 AM
GRUBBY604
Electrical Systems/Wiring
May 10, 2014 06:32 PM
Bolt
Jul 6, 2006 12:13 AM
arls544
Dec 30, 2003 02:15 PM
