Vibration Update
Old Dec 2, 2004 | 09:13 PM
  #91
Labrador's Avatar
Labrador
Why would Ford hire Eagle Picher Automotive & Visteon if they did not have vibration problems...mmmmmmmmmm?
I gave this news release to the DSB, it was my smoking gun.
http://www.epcorp.com/NR/rdonlyres/...FORDRELEASE.pdf
"Visteon Corporation employed the industry's first self-contained Portable NVH Dynamometer to improve noise, vibration and harshness (NVH) on the new Ford F-150."
http://www.auto-innovations.com/actu-news/020.html
Here is a link to see a Hunter Road Forced Balance Machine that most Ford Service Dealers are now using.
http://128.242.141.111/
Old Dec 3, 2004 | 08:56 AM
  #92
Waldonian's Avatar
Waldonian
Labrador,
"I gave this news release to the DSB, it was my smoking gun.
http://www.epcorp.com/NR/rdonlyres/...FORDRELEASE.pdf"
The link will not open. Can you find another way to post or describe what it states?
Thanks!
Old Dec 3, 2004 | 10:01 AM
  #93
thenetguy's Avatar
thenetguy
Hey Labrador! I could sure use this info as well.
The link isn't working.
I have my DSB meeting next week.
Thanks!
Old Dec 3, 2004 | 04:37 PM
  #94
Labrador's Avatar
Labrador
http://www.epcorp.com/NR/rdonlyres/A...ORDRELEASE.pdf
Old Dec 3, 2004 | 09:23 PM
  #95
Scubadivur's Avatar
Scubadivur
Angry
Thanks for the info. Labrador. I am compiling my notes. I feel a hearing coming.
Old Dec 9, 2004 | 09:34 AM
  #96
Waldonian's Avatar
Waldonian
12/9/04 - newly released TSBs
Hello all,
Note newly released (12/9/04) TSBs on "Vibration Cure.....Today???" post.
TSBs: 04-25-7 & 04-25-8
Old Dec 15, 2004 | 07:55 PM
  #97
DrkShadow01's Avatar
DrkShadow01
Exclamation TSB's
Here is a link to the Ford PDF's.
http://www.tremainegarage.com/tsbs/
Don't count on anything yet. I dropped mine off this morning to start these (6th visit now). Still got the minivan loaner (Ohh what pain!).
Old Dec 15, 2004 | 11:59 PM
  #98
ITDave's Avatar
ITDave
Read This! Possibly Exciting News!!!!
Please refer to my posts in VIBRATION CURE TODAY
This thread is located at:
https://www.ford-trucks.com/forums/showthread.php?t=316582&goto=newpost
Regards,
Dave
Hope this helps!
Old Dec 16, 2004 | 06:51 AM
  #99
hovy's Avatar
hovy
I am glad to see Ford stepping up to the plate.
Old Jan 31, 2006 | 11:12 AM
  #100
persichini's Avatar
persichini
Vibration problems
Well for all of you out there i was going to put my input in. I have had the front wheel hubs and complete brake assemblies replaced twice. And I am currently in a battle with Ford because my breaks locked up going down the highway, mind you vibrations have still not gone away. There is a TSB on this problem they will fix it no questions asked but I think ford needs to look more into this problem. Especially since I’ve uncovered a more serious problem with these trucks, as so have many of you. I'll update you on my Lemon Law Battle.
Old Feb 1, 2006 | 07:42 AM
  #101
ford9c's Avatar
ford9c
Mine vibrates as well. It ranges from almost being non existent to shakeing the passenger seat as I drive. I also have the nibble at around 70mph. I have 2 dealers look at it multiple times and although it got better when the @#$ Generals were replaced, its still there and its really pissing me off. I tell you, just like many others that bought the new f150 with the vibes, if the automotive press had been alittle more honest about reporting these problems, I would have at least waited a year and not bought the 04. It now seems that the 05 and even the 06's have the problems as well. You rarely see that mentioned in the press however. It will probably continue like this until there is a class action law suit, or the Goverment gets involved. Then Ford will cry poverty and proclaim its un American to make them build a truck that doesn't vibrate. They will always have an answer to why they can't fix the problem. I think if the spent half as much time trying to fix the problem as the now do trying to convince customers that it doesn't exist, the vibration issues would have been fixed long ago. Then they could start working on all the other problems.
Old Feb 1, 2006 | 08:10 AM
  #102
Enthused's Avatar
Enthused
Persichini and Ford9c, I noticed that you are the first people to post on this thread in over a year. Having studied most of the threads related to vibration, it appears to me that the vibration issues only go away when you lube the parking brake cable. The cable enters the sleeve at the front of the wheel well, so it gets a lot of dirt and salt in it. This causes the parking brake to drag. So, when the parking brake is dragging, and you hit a bump, the ABS decides there is a wheel skidding and it starts jerking the brakes, which is what it's supposed to do. In turn, this causes intermittent vibration, causes rotors to heat and warp, wears out ball joints and rear-end parts, and probably a host of other problems if it continues for a long a time. The kinds of problems you can expect from a dragging parking brake would include poor performance, poor gas mileage, and weird transmission behavior. Most people rarely use the parking brake, so when they do, it sticks because the cable is corroded. Once it's corroded you might have to replace it, but at least lube it. On my vehicles, I ALWAYS engage the parking brake EVERY time I park. This does several things for me: It helps me keep in the habit of DISENGAGING the parking brake every time I drive. It tests the parking brake every time I drive. It helps prevent the parking brake from corroding and sticking.
FWIW, my '06 F-150 has no issues.
Old Feb 1, 2006 | 11:14 AM
  #103
persichini's Avatar
persichini
Well I guess I should know today because ford engineer is looking at the POS today. I personal would think that the parking cable hanging put while I applied the brakes would have nothing to do with the tires locking, but I guess if it could be the cause of the warped rotor's and the vibrations damaging, or causing a caliper to stick then that would shed some light on it...but then again my problem exist on the front breaks. I just wonder if I should bring it to the engineer's attention of wait and see.
FOWL1
2009 - 2014 F150
Jan 19, 2015 10:37 AM
PrinceValium
2009 - 2014 F150
172
Aug 7, 2014 06:12 AM
Labrador
2004 - 2008 F150
Feb 26, 2004 08:09 PM
79CEEJAY
Jun 28, 2003 10:49 PM
Brendan
Sep 12, 2000 11:35 PM
