One problem solved, now passenger electric window doesn't work...
Old Nov 6, 2004 | 02:39 PM
jeepdude775's Avatar
jeepdude775
Replaced solenoid pack in tranny, fixed problem. Wouldn't you know that the exact same instant the passenger side window won't roll up. It will roll down, motor still works. It seems gears have stripped in gear box or something. Pulled door apart and it seems you have to drill out rivets to get gearbox assembly out. I talked to the guy at NAPA and apparently you can buy a gearbox overhaul kit for $30. Has anyone done this and is it a pain in the butt? What about rivets and/or nuts to re-install? Oh yeah, 1991 Bronco.
Thanks again.....
Old Nov 6, 2004 | 03:34 PM
guzzler96's Avatar
guzzler96
Arrow
There were several post on here last week I think about Autozone having the nylon inserts. I had mine repaired at a glass shop, but it didn't look that difficult. I'll see if I can find that post that had the Autozone part numbers and post back.
guzzler96
Old Nov 6, 2004 | 03:38 PM
guzzler96's Avatar
guzzler96
Post
I didn't think I would find it that quick. Read this post. It has those part numbers towards the bottom.
https://www.ford-trucks.com/forums/s...d.php?t=298012
guzzler96
DanielC
Aerostar
Jan 16, 2011 01:51 AM
Alex from GA
1983 - 2012 Ranger & B-Series
May 24, 2010 11:57 AM
FoMoColover
Aerostar
Oct 3, 2006 09:30 PM
ItchSappinR1
Feb 1, 2006 05:05 PM
