'94 power window update.
Old May 23, 2010 | 10:35 AM
Alex from GA's Avatar
Alex from GA
I had a sound like a gear slipping when I raised the window. The consensus said to replace the regulator so I did; same thing. I also had to help the window up. I replaced the motor and gearbox with a universal(fits several models) unit from Dorman. Wanting to find out what was the problem I took the gearbox apart and found the planetary gears were gone, crunched, bald. The motor came with several wires with plugs and I chose the wrong one; the switch worked backward. Changed to the right one and the window works great. You can change the regulator/motor without removing the window or tracks like it says in the Haynes repair manual. The top left rivet can't be replaced with a bolt and nut so I drove in 2 self tapping screws. This might make it easier for someone else to do the job. Online the total parts were a little over $100.
Old May 24, 2010 | 08:12 AM
pawpaw's Avatar
pawpaw
OK, good feedback.
It might be helpful if you'd post the Dorman part number you ended up with on your 94 model.
It helps if we keep the window glass & track sprayed with silicone, so things slide easier & keep em clear, so ice & snow don't cause such a heavy operating load in winter.
Since my grey matter is known to lay down on me now & then & to help me remember, I spray my power window tracks twice a year, when I'm changing the engine oil & filter!!!!
Sure makes em run up & down easier & faster!!!!!
I lube the door locks, & hinges, hood & tailgate latches then also!!!!
More thoughts of habit for consideration.
Old May 24, 2010 | 11:57 AM
Alex from GA
Drivers side. Dorman part nos. Regulator 740-831 Motor and gearbox 742-270. They fit a lot of other models besides Rangers.
chrisbeery
Apr 27, 2008 07:47 PM
FoMoColover
Aerostar
Oct 3, 2006 09:30 PM
dwarrick
1997 - 2003 F150
Mar 13, 2006 04:58 AM
