1960 F-100 steering conversion
Old 11-06-2004, 09:08 AM
exidenick's Avatar
exidenick
exidenick is offline
I am in the process of doing a restoration on a '60 F-100. I want to keep the straight axle. But would like to add power steering. Does anyone know what type of steering box anf linkage that I can use for this conversion?
Old 11-10-2004, 05:02 AM
angus's Avatar
angus
angus is offline
some kind of Toyota box is supposed to work
Old 11-10-2004, 06:24 AM
exidenick's Avatar
exidenick
Thanks, Do you know the specifics, as to what Year make ?
Old 11-10-2004, 07:00 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
The Toyota 4x4 box is used often on 48-56 trucks, but I don't think I've seen a kit to use it on trucks made after 56. You might be able to modify it to fit a 60, but not sure. Sacramento Ford offers a power assist kit for 57-60 trucks which uses your existing steering box but I know nothing more about this kit. You might check with them.
Vern
Old 11-18-2004, 12:31 AM
Goobzilla's Avatar
Goobzilla
Goobzilla is offline
According to pg 137 of the Mid-Fifty catalog, the Toyota box works with 48-52 and 57-60 IF you fab your own bracket or redrill your frame.
Ron
Old 11-19-2004, 07:10 AM
krautwolf's Avatar
krautwolf
krautwolf is offline
Wink 57-60 steering conversion
No Limit Engineering makes an off-the-shelf kit for this. $286.00 The hard part is finding the toyota gearbox in a junkyard. http://www.nolimit.net/Products/PowerSteer.htm
good luck/Mike
Old 11-19-2004, 07:13 AM
krautwolf's Avatar
krautwolf
Steering kits
a
Almost forgot - the other kit that uses the existing steering box is inferior.
Old 11-19-2004, 07:47 AM
exidenick's Avatar
exidenick
Thanks for the feedback,
Finding a box is not a problem, NAPA has a Reman box for less than $300. I just needed to know which one to use. Looks like I'll start this weekend
Old 11-19-2004, 08:00 AM
Goobzilla's Avatar
Goobzilla
I just bought a Toyota steering box for $50 from a guy in Tacoma. I posted a wanted ad on the local 4x4 board and had 5 of them offered to me in less than 24 hours. $30-$50 price range, just picked the closest one.
Ron
Old 11-19-2004, 08:35 AM
brewster1's Avatar
brewster1
brewster1 is offline
Has anyone mated the Toyota box to the stock column and 3-speed shift mechanism?
jt
Old 11-19-2004, 11:43 AM
exidenick's Avatar
exidenick
That would take some engineering & machining to accomplish that feat, but it can be done using the right flex joint
Old 11-19-2004, 02:51 PM
petes4x4's Avatar
petes4x4
petes4x4 is offline
I think it is a 1985 toyota box
Old 11-19-2004, 05:32 PM
Kecky's Avatar
Kecky
Kecky is offline
The Toyota box comes from a 1979-1985 and it should be from a 4X4. CPP also offers a bushing and collar to use the stock column and mate to the Toyota box. You can check it out at http://www.classicperform.com/produc...ord/F100CS.htm
These kits/parts are designed for 1953-56 but may work for other years.
Kevin
Old 11-19-2004, 10:21 PM
AXracer's Avatar
AXracer
AXracer is offline
for ANY used parts:
www.car-parts.com
thats how I got mine, 80-84 Toyota 4x4 pickup It's a short box ~ 9.5" long and mounts with 2 bolts on each side of the sector shaft. You can get a bolt on or weld on installation kit from Mid Fifties including the correctly splined arm. They also offer the rebuilt box for ~ the same price as parts houses and you'll be sure you're getting the right one. Check em out on line, nice people.
Maryrylee
15
02-28-2019 11:16 PM
halltm
11-15-2017 05:59 PM
mdavis1020
22
05-17-2013 08:42 AM
jls1965
03-01-2012 12:23 PM
65fordman
07-17-2011 07:19 AM
Quick Reply: 1960 F-100 steering conversion
