Disc conversion kit and Power Steering
Old Mar 12, 2011 | 05:11 PM
halltm's Avatar
halltm
I have a 64 F100. Any recommedation on a disc conversation kit and power steering kit on whose to buy?
Old Mar 12, 2011 | 05:54 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
Many guys go to pyp to get there parts. Some buy off CL when guys part-out trucks, and a few more buy a whole vehicle thats not running or to far gone to get what they want then part out / scrap the rest.
There is also the Crown Vic swap. Its more complicated, but gives you lower suspension to boot.
Old Mar 13, 2011 | 10:29 PM
drof46's Avatar
drof46
CPP disc brake conversion. Power brake booster and master cylinder with proportioning valve is available and mounts directly to your fire wall. I had to play with the length of the threaded rod supplied though and shorten it. Disc on front kit was fun to install but well worth the effort. For your power steering question there is a rack and pinion setup but I can't remember who came out with it. I got rid of my 64 several years ago now. I'm a 65-66 only guy from here on out. I've also seen a setup that has a bracket and a Toyota power steering geer box, but I can't remember where I saw that setup for sale. Maybe ebay or slick 60's.
You cannot go to pick and pull and do the swap Z is talking about. 65 up only have this luxery.
Old Mar 14, 2011 | 12:19 AM
Bill W's Avatar
Bill W
here is the best way to gain disc brakes on a 61-64 F100....
Deluxe Disc Brake Kits: 1957-1964 Ford Half Ton
the rest is as simple as getting a disc/drum, master brake/power booster (that is if you want power brakes), from a 70-79 f100, along with the porp valve,buy/bend your hard lines and your done.
Old Apr 17, 2017 | 04:01 PM
RacerJames's Avatar
RacerJames
I did an Aerostar front end swap on mine in 2003. Yes, it changes the wheel bolt pattern, but, if you then do the T-Bird IRS and add the Mustang rear hubs to it (Which I plan to do this summer), all your wheels will match again. The Aerostar is almost a bolt in, I removed the trans/rear motor mount crossmember from the original frame and installed a 351W AOD combo. I had to fabricate motor mount brackets on the engine to fit aerostar motor mounts (Because Aerostars never had v-8s), and I used the trans mount crossmember from a '68 T-Bird (because I had one) but that could be fabricated from a piece of tubing. I did a power brake booster and steering column swap from an '81 F-150 at the same time. Good thing the steering column is a tilt wheel because it would be in your lap otherwise. I'm still refining that part of it because there is an interference point between the fuel pump, steering shaft and oil filter. I have to use the short filter, and I rerouted fuel lines slightly to clear the steering shaft.
A little research will reveal that the stock Aerostar and the '90s T-Bird weigh around 4000 lbs which is the same as my '64 short wide. I have continued to use my truck as a truck and it seems to be sooo much better than it was originally. it handles better, stops WAY better, and works hard as a racecar hauler, dirt mover, appliance hauler etc.
Some pics of the Aerostar front end in my truck (sorry about the dirt and grime, it's been 14 years already!):
Redneck steering shaft and bracket
upper control arm mounts, engine side
Lower control arm, Driver's side
left inner tie rod boot, and steering shaft
made an extender box for the steering column and brake booster
Clearance issues with the fuel pump and oil filter
the stance of the truck with original rear end and Aerostar front end
Left side upper control arm (had to reach around the tire for this shot, sorry for the blur).
Old Nov 12, 2017 | 02:38 AM
CJs Hot Rod Shop's Avatar
CJs Hot Rod Shop
Disc brakes on 57 to 65 Ford pu
I have new complete set for 57 to 65 conversion still in box. $300
Old Nov 13, 2017 | 03:18 PM
vze2c2gb's Avatar
vze2c2gb
I also have a 64 and went with CPP Classic Performance Products front disc brake kit. For power steering I went with the rack and pinion kit from POL Performance Online. This allows you to keep the solid front axle and works great. I also replaced my stock steering column with an Ididit tilt and relocated it closer to the dash which improves the room greatly as anyone who has a 64 would know.
Old Nov 14, 2017 | 06:46 AM
john jamieson's Avatar
john jamieson
I seem to remember another power steering option that used the electric gear driven steering assembly from a small car. You cut the column under the dash and splice it in from what little I remember.
Old Nov 15, 2017 | 05:10 PM
CJs Hot Rod Shop
Disc brakes for your 64 Ford p u
I have brand new unused kit except for power master cylinder for sale. CJ. 1/2 price of LMC kit. Just sayin.
Old Nov 15, 2017 | 05:59 PM
TA455HO's Avatar
TA455HO
Lead Gopher
You might want to familiarize yourself with the forum rules and guidelines here
https://www.ford-trucks.com/forums/9...-enforced.html
Specifically,
User Posting Classified Ad In Forums
Lasts: 6 Months
If we could all be selling our wares in the general forums they would become nothing but classified ads.
Thanks
Chad
Wildcat Fords
16
Nov 21, 2021 06:25 PM
hfd315
Sep 25, 2017 01:30 AM
shore
19
Aug 24, 2017 10:24 AM
denny7170
Oct 19, 2016 01:05 PM
Marklea
Jul 27, 2016 12:41 PM
