Rear spring swap
Explorer springs
I got the springs and hangers with the 2000 Explorer diff I am installing in my 1950 F47, 1/2 ton. After much deliberation, measuring, I decided to look for more compatible donor; based on the Explorer springs too long, would have interfered with the rear running board mounts. Mounting on under side of frame , under axle with 2" lowering block would have given stock height, bry my calculations.
I elected to go with 1990 Nissan 2WD springs(2 3/8"), same length(44 1/4"). Yesterday I added a leaf from the stock springs. I am fab'ing mounts that fit to rivet pattern of old mounts. By mounting mounts flush with bottom of frame rail; and under axle I hope to have stock height. If not I will add lowering block.
Will post picture next week, on my gallery if all turns out.
Tom
Tom
