Wasing Machine fills when off
Old Nov 2, 2004 | 08:31 AM
1081's Avatar
1081
My Whirlpool washing machine will drip water into the barrel from the top while off, and fillup the drum. Any ideas? It did this about six months ago and then stopped. Is it a bad valve or something?
Thanks
Old Nov 2, 2004 | 08:49 AM
Big Orn's Avatar
Big Orn
Thanks
Sounds like a mixing valve. Click here for the fix.
Old Nov 2, 2004 | 09:41 AM
Freightrain's Avatar
Freightrain
Since I moved, my washing machine started acting up also. It constantly leaves water in the drum...making washing towels a real bear . It usually takes a second rinse cycle to get the water out.
The only difference now is I don't have a tub to drain in, only a direct pipe which leads UP and over a wall to the drain. I think it is having a hard time getting the water over the wall...in turn letting it leak back into the drum.
Unfortunately the sewer is near the floor joists so it's an uphill climb no matter what. Real bummer
Old Nov 2, 2004 | 10:03 AM
Big Orn's Avatar
Big Orn
Yep, you got a little too much head pressure there, Freightrain. Ever tried a lift station - small one in a sump? This may be your only cure.
Old Nov 2, 2004 | 10:28 AM
spikedog's Avatar
spikedog
Great link, Big Orn. Gave you a star.
Old Nov 2, 2004 | 02:30 PM
Big Orn's Avatar
Big Orn
Thanks, spikedog.
I needed that.
Old Nov 2, 2004 | 02:39 PM
1081's Avatar
1081
You guys are great! I knew someone would have the answer. The link doesn't display the pictures but I can do it with the instructions.
Thanks again.
ranger1999 Bob
22
Jan 4, 2010 01:58 PM
7283-F250
Sep 3, 2006 10:26 AM
FlaresideGlenn
Jul 4, 2005 04:33 PM
sierraben
Jan 8, 2005 12:31 AM
FlaresideGlenn
Jun 19, 2004 04:14 PM
