MSD causing this problem?
Old Oct 27, 2004 | 04:50 PM
84f150guy's Avatar
84f150guy
Exclamation MSD causing this problem?
I have an 86 f150, 351c (from a 75 or 79 ford)....i'll be riding down the road, and the teach will read at a steady 4900-5100. then it'll read 6000...then it will spin around like a clock, read correctly, sit at zero, then go back to the correct reading.
i also noticed, that when i punched the gas when i was doing this, it's a total pig, no acceleration, no pickup, nothing.
also, when i shut it off during it's little tach-dance, and try to crank it back up it either a) won't crank or b) rur...rur...rur... until it cranks.
any ideas? anything would be helped, I'm not ready to pay the $55/an hour to have it looked at!
Old Oct 27, 2004 | 04:56 PM
84f150guy's Avatar
84f150guy
MSD problems 351c
Old Oct 27, 2004 | 05:02 PM
scottie2hottie's Avatar
scottie2hottie
To me, it sounds like a problem in the timing. I can't see where the tach and engine problem are connected though. Isn't your tach connected to the coil? I honestly think you need to time the truck according to specs for the engine, and consider buying a new tach. That's what I would do anyhow, and I'm not familiar with YOUR ignition.
Scott
Old Oct 27, 2004 | 05:36 PM
monsterbaby's Avatar
monsterbaby
on the tack issue get a tack adaptor from msd some tacks don't like the msd box, but hte adapter cures it, and I would try that first it may cure your whole problem.
Also they quit making clevelands in the us in 1974 so if it's from a 75 or 79 then it would probably be a 351m/400.
Old Oct 27, 2004 | 08:08 PM
paragod's Avatar
paragod
Has the problem been occuring since you put the MSD in? You might check and see if the tach is compatible with MSD. I agree about the timing too.
Old Oct 27, 2004 | 08:26 PM
Torque1st's Avatar
Torque1st
Posting Legend
Please do not cross post!
Anthony487
16
May 30, 2016 05:34 PM
thrdofmny
Modular V10 (6.8l)
Apr 25, 2016 07:37 PM
katzklaw
Jan 14, 2016 02:30 PM
Dustin_86
Electrical Systems/Wiring
Oct 12, 2004 10:58 PM
Ammie
Apr 21, 2004 04:19 PM
