cleaning spark plugs
Old Oct 27, 2004 | 01:14 PM
el conquistador's Avatar
el conquistador
what are some good, safe methods for cleaning spark plugs?
i ran some seafoam through the intake via a vac line and the plugs seem like they are fouled and need cleaning (i was expecting that). the idle sucks but the truck runs fine at higher speeds. sometimes when i start it up, the engine wants to die. BTW, i recently changed the IAC and TPS (non adjustable on 91 2.3L). i was just hoping i could wait til this weekend but it wont happen. I will also pull codes and check the vacuum for safe measure. any other suggestions while i am doing this?
thanks in advance,
E.C.
Old Oct 27, 2004 | 01:51 PM
Dan Robertson's Avatar
Dan Robertson
For what spark plugs cost, I wouldnt bother to clean them. Replace them and save yourself some time and aggravation.
Dan
Old Oct 27, 2004 | 04:20 PM
el conquistador
i would rather clean them since they are not that old and they are double plats so any other suggestions?
Old Oct 27, 2004 | 04:33 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Sandblast and clean well.
Old Oct 27, 2004 | 04:45 PM
CobraXP's Avatar
CobraXP
Get one of these:
Spark Plug Cleaner
I have one, but haven't used it in a while. I used it on all my boat and jet ski plugs. Boats are not as bad, but any 2-stroke engine is known for coating plugs...
Old Oct 27, 2004 | 08:17 PM
Ken00's Avatar
Ken00
Brass brush should do it.
Old Oct 27, 2004 | 11:07 PM
99xlt4.04x4's Avatar
99xlt4.04x4
Have you checked the EGR?
Old Oct 28, 2004 | 01:40 PM
el conquistador
Thanks ken, i had a brush in mind and i have never had to clean plugs so i didnt want to damage them
replaced that recently, too.
Old Oct 28, 2004 | 02:36 PM
pawpaw's Avatar
pawpaw
On cleaning spark plug insulators, I use baking soda & a orange stick.
The combination won't put marks on the ceramic like some metal bristle brushes will & the orange stick won't chip or scratch the ceramic. It'll also easily trim, so the tip will get into those hard to reach places & it's hard enough to last. The baking soda rinses off easily too.
Will also make those 2 cycle surface gap plug insulator's look like new too.
OH btw, for those of you that don't know what an "orange stick" is, just ask your sweety, bet she has a supply of the small 1/4 inch diameter ones in her fingernail beauty kit.
icentropy
Feb 20, 2014 09:42 AM
makthenif
May 2, 2011 06:09 AM
someday
General Automotive Discussion
Sep 19, 2010 09:09 PM
NeedHelpBad
May 28, 2003 05:29 PM
KentuckyFord
Apr 23, 2002 10:29 AM
