hub lock does not move
Old Nov 3, 2004 | 06:13 PM
jjohn82's Avatar
jjohn82
I did more than spray. I submerged the interior in a mix. Put them in a tupperware container or something. You just need enough fluid to cover the bottom inch. Fill the container and then the inside and let 'em soak.
Old Nov 4, 2004 | 11:35 AM
dougger222's Avatar
dougger222
I've had the problem with the 99 F250. The driver side got really tight a couple years ago and ever since that they were junk. The hub was removed and cleaned and not long after it stopped working. When the front end was replaced Warn's were installed and there great. $170 for both sides at Napa, $100+ each side at Ford. When the X has problems I'll go with the Warn Premiums, $185 for both sides.
Old Nov 4, 2004 | 02:32 PM
wipper's Avatar
wipper
before i reassemble my hubs where and how much grease (i guess type too) should i use
Old Nov 4, 2004 | 07:33 PM
jjohn82's Avatar
jjohn82
Well, I guess by this it worked. I'll be honest, I just put mine back on after the soak; but any light grease should do the trick. I've got about 30K on them so far and they still turn. Depending on what you drive in, taking them off and doing a clean 'n lube is a good idea.
Old Nov 5, 2004 | 01:07 AM
wipper's Avatar
wipper
i used a light coat of bearing grease on the inside and out side splines, but they will probably need to be replaced in the spring they just dont seem that smooth when turned
brandonmartin
21
Feb 9, 2012 01:20 PM
gordo2
Offroad & 4x4
15
Mar 29, 2010 10:09 AM
Jager
Sep 26, 2009 05:05 PM
dqdave1
Aug 5, 2009 01:59 AM
hsfbfan
Offroad & 4x4
Jul 11, 2004 10:29 PM
