Changing Fuel Filter
Old Oct 31, 2002 | 07:13 PM
nittany's Avatar
nittany
Hey Guys,
I want to change my fuel filter on my 96 Ranger, but the not sure how to depressurize the fuel line. Also, do you need a special tool to remove the high pressure clips?
Let me know if you can help me.
Thanks
Old Oct 31, 2002 | 07:22 PM
superrangerman2002's Avatar
superrangerman2002
[updated:LAST EDITED ON 31-Oct-02 AT 08:23 PM (EST)]>Hey Guys,
>Thanks
1. locate the fuel shut off switch, it should be under your passenger side dash, if I remember correctly (check your owners manual).
2. Start the truck, then take the shut off switch (pull it away from its mounted position) and tap it gently on something realitavely hard. The vehicle should shut off in a few seconds.
3. with a needle nose pliers and a flat head screw driver, gently pull the clips off the filter.
4. reinstall the new filter in the proper direction, and also using the new clips that should be provided.
5. push the reset button on the fuel shut off.
6. turn the ignition on, but wait about 10 seconds to turn it over.
If you have follewed these steps you truck should run great.
Good Luck,
Super
Old Oct 31, 2002 | 07:24 PM
superrangerman2002
P.S. Welcome to FTE!!
super
Old Oct 31, 2002 | 10:33 PM
nittany's Avatar
nittany
Super,
Thanks for the complete instructions. The only trouble I may have is with the clips because my fuel filter didn't come with new ones.Is it possible to remove the old ones without breaking them? If not, can you buy the clips seperately?
Old Nov 1, 2002 | 01:24 AM
bubbernator's Avatar
bubbernator
I don't know if this applies to the '96 model, but in my '98 the inertia (roll-over) switch is hidden behind the right side kick plate. The de-pressurize procedure is to pull the elec. connector and crank the motor for 2 seconds.
The fuel filter is in the left frame rail, (under driver), held in place with spring clips. The stainless clips that hold the lines in place can be opened and removed without damaging them, but the fuel lines require a disconnect tool. Looks like a split donut, you slip it over the line and down into the fitting. A complete set (A/C lines, Fuel Lines, etc) costs about $10.
Again, I don't know if this applies to your year or model truck. I just learned as I went with mine.
Don't forget to plug the switch back in when you're done.
CB
Old Nov 1, 2002 | 08:35 AM
greenpus's Avatar
greenpus
Filters usually do not come with new clips. You have to go to the dealer and buy them. You can use the old ones but you are better off gettting new ones
>Super,
Old Nov 1, 2002 | 01:09 PM
MickeyP's Avatar
MickeyP
The Ford OEM filter does come with new clips. ($11 at www.fordpartsnetwork.com)
Old Nov 2, 2002 | 02:20 AM
GreenRanger's Avatar
GreenRanger
Ryan Popp
Jan 8, 2013 08:36 AM
rmnkys
Jul 6, 2010 11:24 PM
brazoriastang
2004 - 2008 F150
Aug 3, 2009 06:18 AM
willj86
Sep 25, 2005 05:46 PM
rmelki
Apr 2, 2003 09:18 AM
