need help
Old Oct 23, 2004 | 06:01 PM
ford1967's Avatar
ford1967
need help
i have a stock 352, exept electronic ignition and a hipo coil, and about 500 dollars and i was wondering what should do to it to start the build up. i was really considering headers or a carb but i was wondering what you guys were thinking.
Old Oct 23, 2004 | 06:25 PM
Chris Nikirk's Avatar
Chris Nikirk
Hmmmm . . . For $228 you can get cheap headers, mufflers, and tailpipes from Summit . . . For $240 you can get an Edelbrock 650cfm (man choke) 4bbl carb, and that leaves you almost enough to get a 4bbl intake out of a junkyard to make that work.
I guess it depends on if you're having any driveability problems right now (I'm guessing you might from the switch to electronic ignition). A new carb might make the biggest difference.
Old Oct 23, 2004 | 06:42 PM
ford1967's Avatar
ford1967
no i dont have any problems i just put it on to eliminate the points and condenser and the motor runs perfect.
Old Oct 23, 2004 | 06:55 PM
elemint's Avatar
elemint
I sort of am in the same boat but i am keeping the points. I like to have one vehicle that will work if there ever is a massive solar flare or a nuke hits.
Old Oct 23, 2004 | 08:47 PM
Scouder's Avatar
Scouder
I know Ratsmoker isn't here to support me in this, but He and I agree that the headers and free flowing exhaust are first, followed by intake and carb. The cam and compression come after that.
-Scouder
Old Oct 24, 2004 | 10:04 AM
ford1967's Avatar
ford1967
yeah
that is what i was thinking considering our exaust manifold is so constricted. i was then thinking of putting on a cam shaft but if you think that i should do a carb first then i probably will do that. hey thanks for everything i just wanted to make sure that would be best.
JB78f150
Mar 27, 2012 07:41 PM
adsheppy2004
Apr 30, 2011 07:52 PM
thecowboy
Mar 18, 2005 07:10 PM
farmtruck21
Sep 18, 2001 08:23 AM
