Clothes dryer goes "thump" !
Old Oct 21, 2004 | 03:11 PM
gtex's Avatar
gtex
I thought I'd check with you all before digging in. It's simple GE Dryer, about 7 years old. It sound slike it has a shoe in it with just a regular load of clothing.
I figure somebody here has seen this recently and can save me about an hour of trouble-shooting...any help much appreciated...I've got other things I'd rather be neglecting :-)
thanks in advance
Old Oct 21, 2004 | 03:38 PM
BB's Avatar
BB
My Kenmore dryer thumps on every revolution. The drum (whatever it's called) rests on some small rollers at the bottom. The drum has a folded over seam that is riveted together on the ends but it is a little loose and not very smooth. When the seam goes over the rollers it makes a thump. There are two sets of rollers so it makes a double thump every revolution. I don't know of a way to fix it but it hasn't gotten worse over the years.
Anyway, maybe try checking your rollers. Hopefully that's the problem with yours. They sell replacement kits for the rollers and I think a belt comes with it too.
Old Oct 21, 2004 | 03:39 PM
nick88f150's Avatar
nick88f150
Sorry for asking what seems like a stupid question, but I figure it may be worthwhile.... Does it do this with all loads of laundry? Maybe you may have left a wrench or something in a pocket.
BB- Maybe try welding the seam together, then grinding the seam smooth?
Old Oct 21, 2004 | 03:57 PM
BB's Avatar
BB
Thanks nick, I was thinking about that but was wondering if the heat would warp it and/or crack the porcelain lining inside.
Old Oct 21, 2004 | 04:02 PM
gtex's Avatar
gtex
Yah. mine pretty much does it with all loads. I think it's worth with more mass. Sound sliek the rollers. Probably a pretty common item to show wear.
Old Oct 21, 2004 | 04:45 PM
nick88f150's Avatar
nick88f150
Ah yah, BB. I forgot abt the porelain, It'd prolly do some damage.
Old Oct 21, 2004 | 06:59 PM
shakespearesdad's Avatar
shakespearesdad
Worn out bearing on a roller. Easy fix, about 10 to 15 bucks.
James
Old Oct 21, 2004 | 07:05 PM
jbone108's Avatar
jbone108
check your belt for a flat spot
Old Oct 21, 2004 | 09:34 PM
jaydez's Avatar
jaydez
1. do you have a cat?
2. if yes, do you know where it is?
Old Oct 21, 2004 | 10:17 PM
gtex's Avatar
gtex
No cats and no children..
My dog is about 105lbs, I don't think he's going in there without a fight. And I'll probably lose that one :-)
Old Oct 22, 2004 | 11:15 AM
pchristman's Avatar
pchristman
Keep a shoe in the laundry room, and throw it in with every load - then you'll always know what the noise is.
Old Oct 22, 2004 | 11:48 AM
reever's Avatar
reever
More than likely the support rollers under the "drum". My kenmore had no bearing in the roller, just a oil impregnated brass bushing pressed into the roller hub. Bushing wears away, plastic on hub goes oval and gets bigger, thumping ensues. If I remember, about a $15.00 part.
-reever
Old Oct 22, 2004 | 12:17 PM
5_labsownus's Avatar
5_labsownus
It is most likely the
drum center bushing bad. Some models have "glides" in the front that go bad and others have rollers and they os the bearings go out. Not hard or expensive to fix but takes a little time!
Old Oct 22, 2004 | 08:25 PM
Torque1st's Avatar
Torque1st
Posting Legend
I have seen the bolts/screws on the drum "axle" at the back come loose resulting in a thumping noise.
My dryer has a thump-thump also from the drum seam. Why they don't make that better at the factory is beyond me...
ford2go
Apr 11, 2019 05:08 AM
ford2go
Aug 29, 2013 06:38 AM
ford2go
Jul 20, 2012 05:44 AM
websthes
Nov 8, 2007 09:20 PM
psu1xj
Feb 15, 2005 11:11 AM
