Check Engine Light is Back
Old Oct 19, 2004 | 08:56 AM
jkward's Avatar
jkward
Help Please!
Earlier, I had a Code P1131 and with your help I checked my MAF and throttle body. I cleaned both and found them to not be very bad. Then I changed the fuel filter (it was dirty) and the check engine light went out.
Now, whenever I go on the highway, the check engine light comes on again. It takes a week of in-town driving for it to go out.
There seems to be something about highway driving or the higher speeds. My mileage on this 1996 2.3 is 26 MPG.
What do you think?
Could I still somehow be starving my engine and getting a lean fuel mix?
Any ideas?
Thanks,
John
Old Oct 19, 2004 | 09:41 AM
jaydez's Avatar
jaydez
my B3000 gave me trouble like that when i first got it. every lean code int he book was being throw.... I eventually traced it to a bad O2 sensor.
Old Oct 19, 2004 | 06:08 PM
RangerRuss's Avatar
RangerRuss
John:
Are you still getting a code 1131? My lookup manual says: P1131 HO2S 11 Indicates Lean (Ford, Mazda).
Your o2 sensor is easy enough to check with a vom - see www.forparts.com/o-21.htm
Hope this helps.
Russ
Old Oct 19, 2004 | 11:48 PM
pawpaw's Avatar
pawpaw
I'd run this puppy by your favorite autoparts store like Advance Auto or AutoZone, which locally use the Actron CP9145 scanner which can read PID's, so it can directly monitor O2 output readings. They will scan your computer for codes at no cost too.
How does your air filter look????
How about a intake manafold vacuum leak, or vacuum lines maybe????
Just some thoughts from the sidelines.
Texas John
Aug 30, 2007 04:23 PM
MADSEN
Nov 17, 2006 06:54 AM
walvegas
Aug 19, 2004 10:09 AM
jcb67
Aug 23, 2003 12:15 AM
johns
Jun 20, 2002 10:37 AM
