Check engine light
Old Aug 20, 2003 | 05:58 PM
jcb67's Avatar
jcb67
Check engine light
My check engine came on this morning. Went to Auto Zone and got a free diagnostic check. The code is P0442, called Ford-small emission leak. It will be $67.00 for Ford to do a smoke test and they wont gaurantee that they'll even find it. They also told me the gas cap could be on wrong?. When I got home I took the gas cap off then put it right back on. Is it worth getting the smoke test? Is it possible the light will go out in a couple of driving cycles?
John B.
1998 Expy 4.6
Old Aug 21, 2003 | 09:37 AM
buzzard's Avatar
buzzard
Check engine light
First things first. Disconnect your battery for 15 minutes or so to reset the PCM. This might "fix" your concern, especially if your gas cap is the culprit.
Old Aug 21, 2003 | 11:33 AM
Darth Baiter's Avatar
Darth Baiter
Check engine light
Buzzard, Is there a Sequoia version like this FTE site? Post Expy I might look at those and would rather research the good and bad before rather than after the fact.
Old Aug 21, 2003 | 11:36 AM
DEEP BLUE's Avatar
DEEP BLUE
Check engine light
Other wise you will have to go thru about 4 tanks of gas for it to turn off by it's self. (if the gas cap is indeed the problem) make sure who ever puts in on tight after each fill-up. So try the battery, other wise if you dont want to do that see if it turns it's self off after 3-4 tanks of gas. Odds are it is an emmisions problem, nothing to bad.
BLUE
Old Aug 22, 2003 | 07:18 PM
jcb67's Avatar
jcb67
Check engine light
I disconnected the battery and the check engine light went out, did this yesterday pm and so far so good. The expy even seems to be running smoother now...Is that possible? Thanks for the suggestions!!
John B.
1998 Expy 4.6
Old Aug 22, 2003 | 09:12 PM
HomerWinzlow's Avatar
HomerWinzlow
Check engine light
Did the gas cap set the MIL lamp off in 98? I thought that was only on later models.
Old Aug 22, 2003 | 09:59 PM
PaulC's Avatar
PaulC
Check engine light
Isn't the loose gas cap/MIL signal a feature on all OBD-II vehicles?
Old Aug 23, 2003 | 12:15 AM
jcb67's Avatar
jcb67
Check engine light
I'm not sure what the MIL signal is....Must be on later models....
John B.
1998 Expy 4.6
540iman
Jan 16, 2012 11:04 AM
john 123
Feb 14, 2010 03:16 PM
John Rowe
15
Feb 23, 2009 06:09 PM
paxety
1983 - 2012 Ranger & B-Series
Jun 23, 2004 09:05 PM
jcb67
Mar 5, 2002 07:49 PM
