Tornado/CycloneFuelSaver --Does this work?
Old Feb 16, 2010 | 02:35 PM
g_k50's Avatar
g_k50
Originally Posted by dcpg2000
Clear that it works. I have a light truck hyundai Santa Fe, and works with gasoline and natural gas to carry. immediately it installs cyclonefuelsaver, it gave more power me, and now I must accelerate less to obtain the same power that it generated to me previously. Sell I it in Colombia, and you create you, who I have not received the first return. I do not understand so that the people say that she does not work.
Yo no habla esta englese. No posta here no mora. por favora. Grassiass.
Old Feb 16, 2010 | 07:26 PM
dcpg2000's Avatar
dcpg2000
Thanks for the commentary, but I create, that the people have understood my commentaries with my English poor. I believe that we must deepen but the subject, and not to watch these small errors. thanks.
Old Feb 16, 2010 | 08:05 PM
g_k50's Avatar
g_k50
The English errors are not small, and the product is crap.
Nuff Said, senor.
Old Feb 16, 2010 | 09:05 PM
LMS Residential's Avatar
LMS Residential
Originally Posted by Danger_Dave
the human brain is an extremely powerful pile of mush. we only use a small percentage and geniuses use only a little bit more. if we have the power to cure ourselves with only a sugar pill placebo when told its a medication i think thats amazing.
I think that Dos is taking something a little more potent than sugar pills.
Old Feb 16, 2010 | 09:08 PM
LMS Residential
sorry, meant dcpg, sorry dos
Old Feb 17, 2010 | 09:26 AM
KhanTyranitar's Avatar
KhanTyranitar
Please you review, that you have installed cyclonefuelsaver by the correct side, So that if is placed by the opposite side, generated the effect opposite as have mentioned you it. The car is placed completely moored. to install it but near the possible thing the admission taking. Breadfruit in Colombia the tests directly with the sale concessionaires have been realised, like hyundai, Kia, Chevrolet, Toyota, Mazda, Ford. and all have applauded the improvement of performance in each one of the cars, that if having clarified that marks have been but generous that others, in the diminution of the fuel consumption. But doubtlessly the improvement in power is immediate. Until in trucks International and Kenword they have settled for the oil company. My opinion is not to enter discussion with anybody, since what it is wanted, is that each takes the concept from the device, and the one that does not feel satisfied gives back it, so that the money returns to him. For that reason 30 days occur him to the person so that they use the product they give back or it. Yet the respect, you must it have given back and that their money had refunded you.
Do you get paid to advertise these things?
Ok, lets break down the alleged principles that makes these things work.
The idea is that the fuel does not properly atomize in the engine and that the turbulence these devices generate helps break up the fuel and help it mix more completely and evenly.
However, the manufacturers have already placed the injectors in a location where they are exposed to severe turbulence and even mixing. They place the injectors close to the intake ports. So in order to assume that this device works you also have to assume that additional turbulence is needed over what the factory has already done.
Furthermore you must also assume that the device, which is located in the intake somewhere before the throttle body can generate enough turbulence that it carries through past the throttle plate, into the upper intake chamber, then down the individual runners. This is not going to happen. The distance is too great, and the effect gets canceled out by the throttle plate alone, not to mention every size change and bend. I doubt you could get any measurable turbulence change after the throttle plate.
And as though that is not enough, the intake is almost always under a partial vacuum, the transition to partial vacuum right after the throttle plate will cause any pressure waves and turbulence to collapse.
Then you have to assume that the drag generated by the device doesn't have a greater effect on performance than the turbulence it creates. I think we all know the answer to that one. The drag does have an effect, but it not in the direction we would want to go.
The only conditions a device such as this might work under is older carburated engines and throttle body injection, and I emphasize, might work on. As I stated earlier, I have tested these devices under scientific conditions and found that in each of the tests, the performance and gas mileage on the test vehicles was worse than the control.
Greywolf
19
Feb 29, 2012 01:37 AM
RookieFixer2011
Dec 19, 2009 02:02 AM
oldirtytruck
Modular V10 (6.8l)
17
Feb 3, 2009 10:23 AM
400944
Apr 20, 2008 01:44 PM
glruff
Delaware Chapter
Nov 21, 2007 08:53 PM
