parking brake cable replacement
Old Apr 19, 2008 | 06:40 PM
400944's Avatar
400944
on a 1969 Ford f-100 with brake shoes, how do you replace the parking brake cable
Old Apr 20, 2008 | 08:25 AM
Freightrain's Avatar
Freightrain
The front one? at the foot control?
There is a clip that holds it to crossmember back at the splitter(back where it goes into equalizer for rear cables-if I recall correctly) , then likely you'll have to drop the pedal assy down out to get it off the front. It's only a couple bolts, then pull cable assy out with pedal. There is a clip holding casing to pedal assy, then cable slip out of pedal assy. Then reverse procedure. Not difficult.
The rear ones will take removing the rear wheels and drums to get to cable on the brake shoe itself. Follow it up to where it attaches to front cable and unclip it. You'll like have to loosen adjuster on cable to get it all back together since new cables won't be all stretched out. A bit more involved then front cable.
Old Apr 20, 2008 | 01:44 PM
Mil1ion's Avatar
Mil1ion
Have a read of this
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Adigo
Jan 11, 2016 04:47 PM
Marky48170
Sep 23, 2012 07:00 AM
KillerTux
Aug 13, 2011 11:01 PM
Thipdar
Jan 17, 2011 06:26 AM
