Sponsored by: Auxito
help...suggestions
Old Oct 17, 2004 | 09:30 AM
nasa-hvac's Avatar
nasa-hvac
help...suggestions
while trying to clean my egr to clear a check engine light, i broke the right bolt holding the egr( what a great day this is going to be)....1, should i have allowed the engine to heat up first, would this of allowed the bolt to come out easier, the second bolt seems to be tight as well, and the last thing i want to do is break them both off..2, the only fix i see here is to drill it and try to easy-out the broken bolt, what size threads are on the bolt, it was a clean break, i feel pretty confident i can do this without screwing the threads up, but if it come s down to it, i'll have to run a tap in there. any help here is greatly apprieciated.
Old Oct 17, 2004 | 10:31 PM
bosshoss's Avatar
bosshoss
Hey NASA-HVAC.
bummer dude. My two cents worth are to remove the throttle body with the pleminium or the elbow that bolts the throttle body to the lower intake. This would make cleaning the egr ports a lot better, and repairing the bolt problem. TIP. Tape the 1/4" drive u-joint to the socket and the extension. It WILL save a lost tool. I know. Good luck. Its not that bad to do.
Dave P.
Old Oct 18, 2004 | 04:05 AM
nasa-hvac's Avatar
nasa-hvac
thank you....i will do as you suggest, it has got to be easier than trying to get a drill motor in that small space....thanks again
Guzzo
Oct 21, 2013 11:39 PM
rlandrum
Sep 18, 2011 05:54 PM
colo_dually
Jun 18, 2011 10:10 PM
snagmaster86
Nov 6, 2006 01:50 PM
JohnMMena
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 18, 2005 10:09 AM
