Sponsored by: Auxito
Question About Oil Pressure
Old Oct 16, 2004 | 09:20 PM
biggalaxie's Avatar
biggalaxie
Question Question About Oil Pressure
my truck reads normal oil pressure but once it warms up the gauge pegs eventually, sometimes it will drop back to normal and then suddenly spike right back up. heck sometimes when the turn signal is on you can see it slightly bounce. anybody have any ideas? thanks, matt
Old Oct 16, 2004 | 10:13 PM
superrangerman2002's Avatar
superrangerman2002
Sounds like the oil sending unit is bad.
It is located by the oil filter on the 4.6L and 5.4L motors if memory serves me right.
It should be covered in a chilton or haynes manual.
Old Oct 16, 2004 | 10:19 PM
biggalaxie's Avatar
biggalaxie
actually it only has like18,0000 miles on the sending unit
i guess i could have got a bad one this truck does have 150,000 miles on it
Old Oct 17, 2004 | 08:10 AM
superrangerman2002
If that is the case, I would reccomend getting you motor hooked up to a mechanical gauge an see what the readings are.
What you describe is common with a bad sending unit or the sending unit wire is some how mangled/corroded/shorted out.
Old Oct 18, 2004 | 05:25 AM
Nick_2000's Avatar
Nick_2000
They are not that hard to change. You can pick one up for between $5-$10 at Advance Auto. That was the only thing I've had to do since I got my F150.
