ford 9'' drain plug
Old Oct 14, 2004 | 05:47 PM
ford390gashog's Avatar
ford390gashog
ford 9'' drain plug
is there a way too tap a hole for a 5/16 inch drain plug on the ford 9 ''
Old Oct 14, 2004 | 06:21 PM
mark a.'s Avatar
mark a.
It's too thin to tap, you will have to weld a backup plate inside the housing.
Old Oct 15, 2004 | 04:09 AM
Broncojohn's Avatar
Broncojohn
I drilled a hole just to the side of the ring gear on the bottom back side. Where the rear cover and the lower part of the housing are welded together, on the back of the housing, not the bottom. It took a 1/4 fine thread fastener, because I was drilling thru two piece of steel I didn't use a backing plate. I didn't leak and it took about an hour to drain the pumpkin but I didn't have to reseal anything.
Old Oct 15, 2004 | 07:42 AM
ford390gashog
i was thinking of the same thing do you know how much it took to refill
Old Oct 15, 2004 | 01:06 PM
Broncojohn's Avatar
Broncojohn
I can't remember exactly, almost 3qts. You should be able to find capacity online somewhere. If I run into it I'll post it here.
earthworms
44
Jul 10, 2022 03:54 PM
Texas Bob
Oct 19, 2016 10:07 AM
billb2000
13
Oct 23, 2014 10:20 PM
56efffie
Feb 27, 2003 12:34 PM
jc
Sep 18, 1999 08:34 PM
