A/C Relay
Old Jan 13, 2003 | 10:04 PM
mlkull's Avatar
mlkull
A/C Relay
How do you test a relay to see if it's good? I think my A/C Relay is the reason why my A/C isn't working, but I don't know of a way to test the relay. Can it be done with a voltmeter measuring for resistance?
Old Jan 14, 2003 | 05:23 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
A/C Relay
Swap it with one of the other relays for wipers, fog lamps, etc and see if that makes the a/c work. The a/c relay is only for the a/c diode on the compressor.
Old Jan 14, 2003 | 05:42 AM
mathelm's Avatar
mathelm
A/C Relay
As in Air Condition? The only relay I know of is on the coolent tank. And that one you use a paper clip to jump or short it to engage the A/C clutch.
Old Jan 14, 2003 | 09:06 AM
mlkull's Avatar
mlkull
A/C Relay
So a relay is a relay is a relay? It doesn't matter which one goes where?
Old Jan 15, 2003 | 07:56 AM
Ken00's Avatar
Ken00
A/C Relay
Relays can be different but in most cases they are similar, depends on the year also. The AC has a pressure switch that can be jumped for a short period to see if you have a low charge/bad swtich and a WOT relay that cuts out the AC for WOT.
Old Jan 15, 2003 | 09:40 AM
mlkull's Avatar
mlkull
A/C Relay
I found the WOT relay. I replaced it with another relay which I knew was working. The clutch didn't kick in. So I know it's not the relay. Where is the pressure switch you're talking about? I'll try that next.
Old Jan 15, 2003 | 01:38 PM
mathelm's Avatar
mathelm
A/C Relay
On the coolant tank....
Old Jan 15, 2003 | 04:04 PM
Rand's Avatar
Rand
A/C Relay
Old Jan 15, 2003 | 07:43 PM
Ken00's Avatar
Ken00
A/C Relay
It's normally near the firewall, I'm drawing a blank on the components name right now. Don't run it long when you jump it or you will damage the compressor. This mormally means you need a charge.
burgerking579
Aerostar
18
Jul 20, 2021 12:05 PM
dougsbart
2004 - 2008 F150
May 3, 2011 07:25 PM
Welk49
28
Jan 18, 2009 09:14 PM
tgspencer
Oct 16, 2008 07:54 AM
marragtop
May 8, 2006 05:25 AM
