I don't have an E-brake on my 78 because the are no cables coming out of the drums-probly froze on revious owner who took them off.Well it has a Dual piston Dana 60 I have cables but they are for a 9" will they work?? How to make them work??
Thanks
Dustin
A Dual piston dana 60 sounds like a front axle with disc brakes on it, no cables are required.
" 9" " sounds like it may be a rear differential, again, no cables are required.
How to make them work? you probably can't, go to your local parts place and buy the cables specific for your truck, they are not expensive.
I might be able to help more if you were a bit more clear, sorry.
