'99 explorer e-brake cable slack??
Old Jan 22, 2011 | 12:01 PM
swillett's Avatar
swillett
hey guys,
I am doing some work on my dad's '99 explorer and i'm currently trying to get the e-brake working again.
i replaced the worn-out shoes (what a PITA!!) and now i have to eliminate the slack in the cable. there is ALOT!
i read in the chilton manual that the e-brake pedal has a mechanism that is supposed to automatically suck up any slack in the line. this is clearly not happening.
do i have to reset it or something??
thanks guys
Old Jan 23, 2011 | 07:14 PM
swillett's Avatar
swillett
bump
Old Jan 24, 2011 | 12:55 PM
shorod's Avatar
shorod
If the parking brake pedal is set, is there still slack in the cable? Does it pull on the parking brake mechanisms at the drums? If the cable actuates the levers at the drums, the problem is likely just that you need to adjust the star adjuster for the shoes to get them closer to the drum braking surface.
-Rod
BLACKHAWK_1989
Dec 14, 2016 06:27 PM
FordLou
1997 - 2003 F150
Oct 23, 2013 10:08 PM
JHoffman93
Dec 23, 2009 09:19 PM
davelength
Dec 14, 2009 09:01 AM
93nighthawk
Aerostar
13
Sep 5, 2009 04:34 PM
