Bronco II Ford Bronco II
Bronco2 rough running-- need advice please
Old Mar 3, 2000 | 03:55 AM
Larry's Avatar
Larry
My wifes' Bronco 2 with 2.9 V6 will sit & idle smooth as silk, then all of a sudden it'll start to cough & miss, lose RPM, then just as suddenly it'll pick up again & run fine. Does the same in city & hi-way driving. I've replaced plugs, wires, cap, rotor, TPS but run out of ideas. Any thoughts ??
Old Mar 6, 2000 | 12:18 AM
GregR's Avatar
GregR
Doe's your Bronco got a carb? Have you ever checked the computer codes? How doe's it run under a load ?
Old Mar 11, 2000 | 03:51 AM
GregR's Avatar
GregR
First check the compression,then check the vacuum.If all that is good it my be the EEC relay.Also check the computer codes that will tell you if a sensor is bad. Good luck.
Old Mar 14, 2000 | 04:05 AM
GregR's Avatar
GregR
AbandonedBronco
39
Dec 24, 2017 10:09 AM
1978ShortboxF-150
Apr 25, 2015 10:18 PM
Raidy
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
24
Feb 20, 2014 08:39 PM
JMR
Bronco II
Apr 3, 2003 04:58 PM
larryswelding
Bronco II
Sep 4, 2002 11:22 AM
