Cold Weather Rich Condition
I'm having a frustrating issue in the cold weather. Granted, cold weather usually brings around some drivability issues for carbs, but this is different.
The engine starts like a champ. It was -15° degrees a few weeks ago, and it fired up the first half turn of the key. Then, only about two more starting attempts before it idled on its own. Then, once it warms up, it drives just fine. Overall, it does really well in the cold.
However, I'm having an issue that's driving me crazy, and I can't seem to find any source for it. Also, keep in mind that this happened with the 600cfm Holley I had on there and with the 450cfm QuickFuel I have on there now. So it's not isolated to a single carb.
What happens is, the first 20 - 30 seconds after first firing up, it idles beautifully. Around 12 AFR, exhaust is smooth, etc. Then, suddenly, it'll start sputtering and stumbling and my AFR drops to around 10 (as low as it'll go.) I can listen to the exhaust audibly change as I'm outside scraping ice off the windows.
The AFR will then stay at 10:1 for the next 10 - 15 minutes of driving, even well after the engine's warmed up. It'll struggle to idle around 200 RPMs (often stalling out), the engine's shaking, sputtering, etc. and I have to finagle the gas, brake, and clutch to keep it running at stop lights (which is not my favorite thing). The AFR remains flatlined at 10:1 from 0 to 4000 RPMs whether I'm accelerating or cruising. The whole cab just reeks of gas filled exhaust.
Then, suddenly.... it'll just go away. At the next random stoplight it'll return to a smooth 12:1 AFR at idle, and cruise is around 14 - 15 AFR. It's like it never happened. There's no middle ground. It's just plain done acting up and will not do it again until it sits for a while, and it'll drive beautifully for the rest of the day.
Any clues as to what would cause this? As said, it's persisted through two carbs, so I unless it's an issue with the carb style (ie. any Holley carb will do this), it must be something else. Something in the valve train? Ignition freezing and firing poorly? I have no idea.
Thoughts?
However, it was 15° this morning and I popped the hood after I fired it up and it opened up like normal. However... it didn't act up this morning. So I'll keep checking until it acts up and see if it's opening then.
I would try leaning out the choke 1 notch and raise the fast idle speed a little.
also that open filter and I bet no heating of the intake manifold does not help any.
Dave - - - -
Otherwise, the intake is heated. And if I'm not having this issue acting up, it drives just fine even when it was -15° out (after its warmed up).
The open filter and coolant heated intake really only cause an issue when the engine is cold as I get massive lean spikes when I push on the gas.
The issue I'm having here is a very different thing.
There was a reason the engineers designed the air filter and snorkel as they did.
Here is a good read on the subject: Air Cleaners - ???Gary's Garagemahal
It's something I've had to just settle dealing with after doing performance upgrades. Ice cold air has a lot more oxygen in it than warm, and until my engine warms up, I have some serious lean issues and often struggle to not kill the engine if I drive it when it's ice cold. A snorkeled / heated air intake alleviates this quite a bit by taking warm air from around the manifolds.However, the lean spike issue from the open air element (and using coolant to warm the intake) alleviates gradually over time as my engine warms up. Once the engine is at full operating temperature, my drivability issues from cold air are almost non-existent, as I would expect. Every little smidgen my temp gauge moves equates to less and less lean spikes on acceleration.
This issue is different as it's a sometimes it happens, sometimes it doesn't phenomenon and when it does, it's PIG RICH no matter if I'm idling, cruising, or accelerating, often persisting long after the engine has fully warmed up. Then, like a light switch, it just immediately goes away and full drivability is restored with a good, smooth idle, and a healthy stoich cruise. It's done acting up for the day.
There are also other times, like this morning when it was 15° out, where it didn't happen at all.
And it does not have to be way below freezing to happen.
Heating the in take does nothing for carb icing only helps keep the fuel atomized after the carb.
What you are seeing when it runs better is the engine bay heating up so warm air is pulled into that open air filter assy.
I also think you have a choke issue that needs to be looked at.
As I said Holley's don't have good working chokes.
It is not uncommon to have 1 setting for winter and 1 for summer. Or you get it to work ok for both but it is never great.
Just my .02
Dave - - - -
I know the drivability improves due to warmer air in the engine bay.
My reason for explaining how it behaves is because that's a very gradual thing, that correlates directly with increased engine temps. The warmer it gets, the better it drives. And I don't have a pre-heated air filter assembly anymore, so the difference when it runs cold vs warm is extreme (especially when cold).
The issue I'm having here is not related as it is an ON/OFF scenario. There is no gradualness to it.
Just my .02
Dave - - - -
I appreciate all the thoughts and brainstorming.
In my experience, the ice will look distinctly white in the limited light of the carb throat, & be visible down at the venturi level.
The other benefit of having the complete & working stock intake system, is that in hot weather you are ducting cold air to the carb, instead of hot under-hood air.
This means more oxygen, so more power when tuned accordingly.
The rule of thumb is 1% power increase for every 10F drop in air temperature.......so a free 5+ hp gain, & mileage, is pretty do-able in summer.
