Bronco II Ford Bronco II
bronco 2 stalls out
Old Dec 2, 2000 | 01:46 PM
lrdoane1's Avatar
lrdoane1
bronco 2 stalls out
HELP MY 88 BRONCO 2 XLT IS SICK! IT IS STALLING OUT AT DIFFERENT TIMES,BACK FIRING BLUE/BLACK SMOKE,SOMETIMES QUITS,BUCKING.
HAVE HAD IT IN THE SHOP TWO DIFFERENT TIMES,AND THEY DO NOT KNOW WHAT IS WRONG. HAVE REPLACED THE TFI MODULE AND THE EVC,NEW PLUGS,WIRES,CAP,FUEL FILTER,FUEL PUMP CHECKED FOR PRESSURE AND IT'S CORRECT AT 40. ACT'S LIKE ELECTRIC OR GAS IS BEING SHUT OFF.
lrdoane1@netscape.net
Old Dec 15, 2000 | 01:37 PM
spamman's Avatar
spamman
bronco 2 stalls out
I have an 88 Ranger 2.3l that would idle hunt for a bit. Soon the idle hunt got real bad and it would buck at speed, smoke out the exhaust...etc. After doing the computer check, it replaced the coolant temp sensor (had to remove part of the intake), and the O2 sensor (it was over 12 years old anyway), I realized my funds were dwindling. I decided to begin a random removal of the sensor connections and re-starting to see if the problem went away. When removing the sensor wiring for the MAP (manifold absolute pressure) it evend out and went into "limp mode" and did not hunt but ran a bit rough. I replaced the firewall mounted MAP sensor (about 50 bucks and 10 minutes) removed the negative battery cable for 10 more minutes and started it up and it ran like new. Try that and always reset the computer by removing the battery connection for a bit. Good luck. e3 - spamman
Old Dec 16, 2000 | 12:50 PM
lrdoane1's Avatar
lrdoane1
bronco 2 stalls out
ok have replaced plugs/wires,cap,evc sensors,both map sensors,one on manifold,one on fire wall,haven't changed the pickup coil yet,have been told this could be the problem. or it could be the ignition switch I'm at a real loss as what to do and funds are getting low.also been told that if the computer is bad it will not tell on it's self there's another $98 dollars!
help!
lrdoane1
Old Dec 16, 2000 | 08:16 PM
thelonerangerxlt's Avatar
thelonerangerxlt
bronco 2 stalls out
Just a crazy thought, but check to see if your battery ground wire is tight where it bolts to engine block. Don
"Nothing lasts forever except natural stone and old Ford trucks." (Willie Nelson)
Old Dec 16, 2000 | 08:28 PM
thelonerangerxlt
bronco 2 stalls out
Old Sep 4, 2007 | 06:09 PM
afrosongbird's Avatar
afrosongbird
Unhappy where for map sensor?
I own Bronco II, '88. Where do I purchase the Map Sensor? I was quoted $169.00 plus $45.00 for labor. Also I need a Throttle Body Plate. I do not know much about cars...other than I've dropped $$$ into this one, still runs good but I do not want to be taken to the bank and can't make withdrawals. Can someone offer a few suggestions? Thank you!
Old Sep 5, 2007 | 12:16 AM
fl1a's Avatar
fl1a
You can replace the map sensor. If you live in a area that has auto parts stores, you
can look the sensor up on their websites, if they are a national chain. Autozones
website has info on repairs and replacement. Make sure your vacuum lines are in good shape also.
99ExpyProblems
Sep 28, 2021 11:03 AM
complicated678
1983 - 2012 Ranger & B-Series
Apr 8, 2008 10:39 AM
norg1
Bronco II
Aug 13, 2007 04:57 PM
eric in tn
Sep 25, 2003 12:08 PM
nowbiteme
1978 - 1996 Big Bronco
Aug 22, 2002 05:53 PM
