Bronco II Ford Bronco II
o2 sensor?
Old Sep 27, 2000 | 12:00 PM
berso's Avatar
berso
o2 sensor?
OK, i just got a 85 B2 and i find that it have some kind of o2 sensor on de driver side out take manifuel, but is disconected, the truck is carburated, so i wonder if that sensor is stock or those aren't the stock manifuels?, it look's like it's sucking to much gas, so i wonder if it have somethig to do with it, also in front of the carb is some extrange part, i don't now what it is but it looks like it move the throtle, any idea?
Please help.
Old Sep 29, 2000 | 07:54 PM
tbird6391's Avatar
tbird6391
o2 sensor?
I dont know the 85 carbureted setup but 90 the o2 sensor is on the Y pipe. If it is disconnected, the computer goes to "limp in mode" which is basically full rich. That explain the gas guzzling.
Old Sep 29, 2000 | 09:26 PM
nitro94's Avatar
nitro94
o2 sensor?
Those older systems really don't get a lot of fuel control from the O2 feedback system. Only about 10%. Usually will run fine without being hooked up. I would look to the power valve in the bottom of the carb as the most likely source of rich running.
2000 XLT Flare Supercab Sport 5.4-Auto-355LS-Tow pkg-Bedrug-Xtang Tonneau
Old Jun 9, 2001 | 12:50 PM
dinosaurfan's Avatar
dinosaurfan
o2 sensor?
Old Jun 11, 2001 | 04:11 AM
NitrogenNarcosis's Avatar
NitrogenNarcosis
o2 sensor?
well I have the 85 and it good on gas same engine 2.8 ltr
the egr valve id the thing you see infront of your carb and the o2 sensor can make a dfi it saved me about 3 mpg when I replaced mine also check the carb for sure mine was screwed and I put a rebuilt carb on it and it made a huge dif
truckfella
Modular V10 (6.8l)
Nov 5, 2013 07:57 AM
tsedgar
Dec 17, 2012 04:39 PM
charlie00tj
Bronco II
Jul 16, 2010 05:22 PM
tietje_3
1983 - 2012 Ranger & B-Series
Sep 29, 2006 04:39 PM
Dracoscott
Aerostar
37
Sep 20, 2005 03:07 PM
