FE446 power issue, MSD stuff.
Old Oct 1, 2004 | 09:17 PM
FORD352V8's Avatar
FORD352V8
I am not a fan of MSD. Tried one of there coils once and what a POS! I loved my mallory dizzy, til it was stolen! I had to walk home and get my stock dizzy out of the garage and put it on the truck to get it going. I know run a petronix unit on it. Ill have to chain it down with a padlock or something so this doeseant happen again. Anyway, go with Mallory it is my beleive there equipement is much better quailty then MSD.
Old Oct 4, 2004 | 06:59 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Heya Greg, did ya ever get your MSD situation fingered out?
Old Oct 4, 2004 | 08:51 AM
gtex's Avatar
gtex
not really. It seems to be running a little better. But it still seems to be weak at higher revs.
I'm going to put the timing light on it again, and see where I'm at. Seei f it is still sticking. I may change the stop bushing, to get somemore total advance...but that takes a good bit more work than just changing the advacne springs. I pretty much have to pull the dizzy or the AC compressor.
Where do you guys think I should be for max advance with this engine setup? What advance and at what RPM? 36 deg at 3000rpm, more?... less?.....any help appreciated.
I'd love to see 14s on Wed. night :-)
Old Oct 4, 2004 | 10:07 AM
Freightrain's Avatar
Freightrain
I'd try around 38 total at or near 2500 rpm. You basically want as much timing as motor will take WITHOUT knocking/pinging. This also goes in hand with 1/4 miles time/speed. You basically turn it up til it makes NO improvement or starts to slow down, or until it knocks. Then back it off.
Here's a thought. Pick up one of those g-meters that plug into cig lighter. Find a nice deserted road and play around. That way you don't have to go to track to find some improvements. Those new versions are pretty cheap anymore, I bought the one from summit like 15 yrs ago(Vericom was the brand) and it was $250, now they are like $50.
Old Oct 4, 2004 | 11:39 AM
gtex's Avatar
gtex
It's not a big expense to go to the track here. It's like $15 for test and tune night. On wednesdays, I can get in a lot of passes. I plan to go this wed. and take the tools needed to adjust the timing and a variety of springs and bushings ;-)
Old Oct 4, 2004 | 01:35 PM
EgoMan's Avatar
EgoMan
Doesnt msd have an ignition module that has the timing advance and retard placed on a dial you can mount in the cab?
Old Oct 4, 2004 | 01:59 PM
gtex's Avatar
gtex
I think MSD has plenty of Retards, not sure about any advance :-)
Old Oct 4, 2004 | 02:33 PM
EgoMan's Avatar
EgoMan
LOL... I know ive seen them before...I was thinking it would be a good way to help test and tune quickly....but then again Im not sure if it does It in the way your needing.
Old Oct 4, 2004 | 05:05 PM
EgoMan's Avatar
EgoMan
Is your cam creating enough vaccum to operate your vaccum advance properly?
Old Oct 4, 2004 | 05:06 PM
gtex's Avatar
gtex
well gyus, I did a little more trouble shooting today.
It looks to be at fuall advance by 2500rpm. It's only at about 32 BTDC at max advance. The return is working. Initial advance is just be ow 20 BTDC. So, I think I need t ogo to the next smaller stop bushing on the MSD Dizzy to get the total advance a few degrees higher.
But the real problem, after a second or so at higher RMPs, the timing starts to jump around. I think that there is a cross-talk problem at higher revs. this explains my intermittent power problems! Aside from ordering the DUI, what can I do? I have new wires, a new cap and a new rotor! Their big cap conversion would probably solve my issue...but it does not fit the FE Dizzy...go figure. I actually ordered it, and found out afterwards that the FE dizzy is an "exception".
ahhhrrgggggg
I think if I can resolve this ignition problem, the truck will be wicked fast!
Old Oct 4, 2004 | 05:07 PM
gtex's Avatar
gtex
MSD billet dizzy, no vacuum advance. all mechanical!
Old Oct 4, 2004 | 05:18 PM
EgoMan's Avatar
EgoMan
Ahh so you think your cap is cross firing,? and the billet cap cant be converted to the large cap like the OE ones can?
Old Oct 4, 2004 | 05:58 PM
  #28
strokster's Avatar
strokster
Timing
Are you using a dial back style timing light? It appears that you are by the posts above.
20 degrees initial seems like a lot. I don't have that much experience with the blue oval motors, but I would think you should change the stop bushing to get more than 12 degrees mechanical. Shoot for 20 to 26 from the Dizzy if you can get it.
I don't rely too much on initial timing other than getting a ball park and then calculating how much mechanical I'm getting. Most performance engines like to see 5-10 initial with 32-38 total.
Some of your other problems, running hot, hard starting, (dieseling??) are caused by too much initial timing.
Get a good baseline that gives you a reasonable amount of intial and total, then play with the springs to see what she likes best as far as how quickly the timing comes in.
Not to defend MSD, but my personal experience has been very good (knock on wood, cross my fingers). I'm running a 6-AL box, Blaster II coil (for 3 years and about 30k) and now a pro-billet dist. I had to mix springs to slow the curve down a bit from the factory settings, but I'm running relatively low compression (10.2) with a lot of duration (244/250 @.050)
Old Oct 4, 2004 | 07:40 PM
  #29
EgoMan's Avatar
EgoMan
I think stock for FE's is between 8 and 12 degrees initial maybe even 14. I thought you would want 38-42 total, but i cant remember.
Old Oct 4, 2004 | 08:35 PM
  #30
Scouder's Avatar
Scouder
"20 degrees initial seems like a lot."
I agree. With your cam and stuff Greg, I can't imagine having it that high. You would be up in the same neighborhood as I am.
The problem with your numbers is this; you have the same dizzy I do, and there is no way to tune it to give 20/32 like you said. They come with 18,21,25 and 28 degree stop bushings. The largest bushing, an 18, on top of 20 initial gives 38. I think a good starting point for you would be 10 initial, and the red stop bushing (28) for a 10/38 with one light silver and one light blue spring. This should have you all in by 3000. Tune from there. If, indeed, you have 20/32 then there is something wrong.
-Scouder
